Which spoiler are you putting on?
You have some wiggle room for the offsets but that seems fine. Seems like popular offsets for the front range from 30-35. Even lowered( mine is lowered on Arks 19x8.5 +35 19x10 +40) with no rubbing issues. I’m also trying to wear out my stock tires but not sure how much longer I can wait lol.Hi guys, need some input. I'm looking to purchase Stance SF07 bronze for the old lady's white Stinger.
Size will be 19*8.5 front 19*9.5 rear.
Debating which offsets to run, as of right now I have +30 front and +40 rear in my head.
I'm on OEM suspension and will reuse the stock tires till they wear out, then go a little wider. I understand there will be a little stretch and that's fine
I don't want serious poke or rubbing. I tend to load up the car with weight a few times a year for travel. I may go on ark gtf springs possibly too.
Are those offsets ok or should I do +32, +34 front and a +42 rear for more clearance from the fender? I have been unable to reach the manufacturer for sizing/opinion options.
I did exactly this at +35, 8.5’s all around That way I can get the same size tires later and be able to rotate the tires.Hi guys, need some input. I'm looking to purchase Stance SF07 bronze for the old lady's white Stinger.
Here's my contribution
Avant Garde M580 in Brushed Bronze
19x8.5 ET35 square 255/35R19 on Michelin PSAS4
View attachment 61020View attachment 61022View attachment 61021View attachment 61023View attachment 61024
Dear Mr. "Schpok", I have a Stinger with Fondmetal 20 "original Kia black wheels. I would like to mount the original 19" Kia Stinger 19x8,0 and 19x 8,5 wheels.Hey Guys,
Since I haven't found a thread for Aftermarket wheels, I post all Pictures here.
Feel free to extend the list.
It would be great if you have Names and Sizes to them.
What tire sizes?New wheels have been put on. Only problem is that front driver side is leaking a bit. Will have to fix it on Monday. :/
Decent amount of poke in the rear, probably some occasional rubbing and witness marks.Looking at this set up...
20 x 9.5 frt +35
20 x 10.5 rear +35
Thoughts, verbal ridicule, advice? And go....
Nuff said. Cant test fit due to no tires on them. Stupid good price but not willing to chance anything to save a buck. Much appreciated!!Decent amount of poke in the rear, probably some occasional rubbing and witness marks.
I suspect strut contact up front. It would be too risky an experiment for me having seen the strut clearance of 20x9 +32 and +30 on my setups.
Is this a set of wheels you could test fit?
I do a test fit before mounting tires for caliper and suspension clearance, just to be safe. You get a good sense of tire clearance at this time as well.Nuff said. Cant test fit due to no tires on them. Stupid good price but not willing to chance anything to save a buck. Much appreciated!!
For 9.5 up front, you need <+25 offset to clear struts. Most people do 9.5 +23-25 with 245/255 and it works. Rears will poke out quite a bit and you’ll rub on dips going fast.Looking at this set up...
20 x 9.5 frt +35
20 x 10.5 rear +35
245/35/20 and 285/30/20. The tire leaking went away and fixed itself after a few weeks, which is strange but I’m not complaining.What tire sizes?
Thanks for the info. Ive decided to pass on the wheels, before even @Hawk853 hit me with some knowledge as well. More i thought about it 9.5 on the front was just big. But not knowing exactly offset stuff im super happy for the help.For 9.5 up front, you need <+25 offset to clear struts. Most people do 9.5 +23-25 with 245/255 and it works. Rears will poke out quite a bit and you’ll rub on dips going fast.
