djerickd
1000 Posts Club!
That was just pump gas with E48. The jb4 was only on to supply cpi flow. And take a log ofcourse. Lozic ecu,tcu
Were you AWD?
@Williamsj41 are you running any aftermarket exhaust parts? I like that my car is quiet and would like to keep it that way but would also like to be in the 11sThat was just pump gas with E48. The jb4 was only on to supply cpi flow. And take a log ofcourse. Lozic ecu,tcu
These were some short pulls on strait ms109 with the lozic 1.5 if anyone was curious about the octane and timing.
I finally installed my remapped Lozic Ecu
1.4 bar.
My only way to measure 0 to 60 is with JB4 Map 0. But I do not know how accurate the times are.
Stock- map 0 2 runs- 4.876, 4.9
Map 2- 4.625
Map 0 Lozic ECU- 4.150
Map 0 Lozic ECU and TCU- 4.1 (spun alot all season tires) gonna take some practice with TCU.
I also noticed a few things. On run with lozic ECU, TCU & Jb4 map 0. Started in 3rd gear manual mode about 30-40 mph full throttle to 5th gear 110-115.
When I started breaking down to about 70mph it automatically downshifted.
Today I did another run with JB4 disconnected and performed flawlessly.
The other thing I noticed is not until I disconnected JB4 was that the shifts were not as harsh.
Do you turn traction and stability off?I found you need to launch fairly soon or too much boost is built, which causes the spin.
YesDo you turn traction and stability off?
1.4 bar.
Map 2- 4.625
I do, slightly or just coincidences.So you think JB4 is somehow effecting things even on Map 0?
I do but why? Just to shift earlier and stay in the power range?Yes I do to. And you have to paddle shift even with the tcu tune
That's niceDid a little better
Nice, what boost level are you leaving at?Did a little better
