[DIY] [Guide] Drive Mode Memory Module (prototype)
Anyone want to make a plug-and-play adapter that includes the right connectors, etc, so we don't have to do posi-taps? I have done posi-taps before, but I'm not a huge fan..
ive had a few discussions about PnP adapters and settled on it being too complicated, it's two connectors that are tapped into, the connectors that I was able to source are expensive ($15 per side for a total of $60 not including any wires) and would have to be assembled by hand. If somebody else came up with it that'd be awesome, they could even work with me to sell them on my site. but I personally have no plans for a PnP adapter
if you want, pm me the parts that you sourced and i'll see if I can find something that'll work.
@budzique got my KSDM3 today - thanks for getting it out quickly! Got it all hooked up - the only thing is it won't remember Smart or Custom drive modes - if I turn the car off in Smart it turns back on in Eco and if I turn the car off in Custom it turns back on in Sport. Shutting off in Sport works as it should as the car comes back on in Sport mode (which I use most of the time anyways). Any tips?2C520E63-4812-4DF6-97D0-F20BBC03E36E.webp
@budzique got my KSDM3 today - thanks for getting it out quickly! Got it all hooked up - the only thing is it won't remember Smart or Custom drive modes - if I turn the car off in Smart it turns back on in Eco and if I turn the car off in Custom it turns back on in Sport. Shutting off in Sport works as it should as the car comes back on in Sport mode (which I use most of the time anyways). Any tips?View attachment 57345
Can you shoot me a message on Facebook (fb.me/budzique) we’ll troubleshoot the problem or see if you need a replacement
So I'm installing the KSDM3 but don't know which red and yellow wires to use on the ISG side. There is only one black so I can figure that out.
And for the mode side, I want to verify it is the last two wires shown on the far right side.
Thanks!
So I figured it out and it works great. Found this diagram which helped for the ISG:
Got this installed and it works great! Thanks @budzique
Just installed mine and have the exact same issue, I don't really use either of those modes but wouldn't mind knowing what causes it.
I did notice for me SMART mode is not saved as it goes back to ECO.
CUSTOM is saved though which make me happy. Maybe each trim operates differently?
Just installed mine. Pretty straightforward install with the help of previous pictures on this thread. I dont see any immediate issues and seems to work as expected.
Thanks all!
I couldn't find this question in the thread but I'm curious if this will work for the Genesis g70? I know it shares a lot of the stinger platform, chassis wise. But don't know about the brains.
Shark racing has the ISG/auto hold, seat memory and door lock proximity modules for the g70 but nothing for drive modes.
Really hope this will work.
Also, has the ambient lighting option been developed yet?
The g70 is an unknown I have been trying to get in touch with a friend that lives 3 hours from here but haven’t been able to connect. I do have the developer kit available that can be used to set everything up and ensure any coding changes can be made if needed. I designed it to be wide platform for developing on other Hyundai/Kia/genesis products if you want
Installed today, works great. Thanks again
Any updates on weather or not this will work on the G70?
I've been driving with one of these installed for about 2 months now. For the most part it works great, the trick is you have to give the board a chance to remember the drive mode. If you start the car, change the drive mode, then turn the car off, the settings wont save.
The only problem I'm having is the Auto Hold keeps turning itself on. I tried to narrow down if there was another function that was causing that but it seems to be intermittent. Not sure if anyone else is running into that issue. It could be because of the 22 year model?
I've been driving with one of these installed for oynbout 2 months now. For the most part it works great, the trick is you have to give the board a chance to remember the drive mode. If you start the car, change the drive mode, then turn the car off, the settings wont save.
My 2020 also has the issue with auto hold turning on randomly at startup. About 70% of the time.
Same here on a 19 but only about 30% of the time.
