SoCalSHO
Ordered them for mine. I will wait on the center section. I have a 2021, which does not light up. It is also easier to justify the purchase if I split up the parts.
You are right down the street from me (I'm in Brea)Ordered them for mine. I will wait on the center section.
I don’t know. But if you want to center, it is $1100 and the install is more complicated too. It requires you to drill a couple more hold to accommodate the revised bolt pattern. The videos at the top of the post show that.Wouldn't it look weird on a 2018-2021 if you don't have the middle section to match the new turn signals?
I think you maynbe right, I will probably order the center section, but I will post photos without it.Wouldn't it look weird on a 2018-2021 if you don't have the middle section to match the new turn signals?
You can get to the screw with a 10mm ratcheting wrench. I ended up having a body shop take them apart for me. This would have been easier. Oh well.How did you take it off without taking the body colored panel off? There is a screw behind it.
did you open up the entire headlight or just took out the lightbulb?The reason I know this is because I have already disassembled it. The bottom light is most definitely incandescent.
The top is merely the way to disconnect the harness from the LED strip.
Are you trying to replace the entire part, or modify what you have? If you want to replace them with the 22 KDM lights, it shouldn't be a problem. It is just plug and play. If you want to modify them, you might be better off getting the sequential reflector replacements they sell on various stinger stones instead. He was talking about the 22 tail lights, and I couldn't figure out how to modify those to work like the KDM lights because the US is a single incandecent while KDM is ~16 LED's.did you open up the entire headlight or just took out the lightbulb?
curious if its easy to take off the outer lenses
like it just pops off or if it needs to be cut?
wanting to try and do sequential on the 2018-2021 model style but curious how hard it'd be to even get to the area
Wow that looks Awesome! I just order my rear LEDs as well. It was just plug and play! That’s great! Glad to hear it is just drilling holes. Also where did you get your black GT emblem?View attachment 60310
I am liking the lights so far. Only broke one tab trying to remove the painted trim from the right taillight. Took about 90 minutes. Had to enlarge a couple holes and drill two more for the center section. But all the electrical was plug and play.
Thanks. It is just plasti-dip, shadow black HyperDip aerosol.Wow that looks Awesome! I just order my rear LEDs as well. It was just plug and play! That’s great! Glad to hear it is just drilling holes. Also where did you get your black GT emblem?
Could we get the part number for the Center bar too?View attachment 60310
