On this car you can gain a lot of power with just deleting secondary cats and cat back exhaust.also with intakes it’s probably in the 30 hp to wheels give or take. Then slap a tune on it with one of the many chips out there . I prefer JB4.this car comes really clogged up from factory on intake and exhaust sides.
Not sure I can get away with that in my state, I will check.
I heard that MBRP is heavier than stock so that will actually reduce performance.
Is Borla lighter than stock?
Lighter should increase performance... duh :p
Shipping box and all parts 78lbs total...with MBRP.
Borla exhaust rock. Best sound on a stinger in my own opinion.also just drop those secondary cats with intakes and back half exhaust. The car will still pass smog and it will fly .
Thanks, Borla over MBRP I keep reading. Want to hear the Borla in person I think one of the UT guys is getting it installed soon.
BMS over AEM or Injen? Been reading nonstop on what airintake to get. Have not seen anyone give temp numbers for each. Want to make sure that I am not having heat issues when it hits 110 outside.
Thanks again for the input still learning.
I have tork motosprots cai works good my ait in summer in Florida on hot summer day are about 110 average
110F is an intercooler issue, not intake. When it's 110F, it won't matter which intake you have. Intakes will give you more air flow, but when it's hot, it's hot.
I think the exhausts all fit the 2022 but you'll lose the electronic valving. it's best to reach out the the manufacturers though.
Shoot can you put the 2022 system on the older cars?
How bad will the drone be on a 3.3 with a Borla catback but using stock tips?
Hella bad.
pretty bad.
Dang! :(
Hella bad.
Dang! :(
I do not want to spend $1000 on Borla exhaust tips and the aftermarket exhaust tips I've seen online from Aliexpress require cutting/welding and messing around with the stock bumper. What would you cool cats do if you were in my shoes? I do not want to mess with my bumper. :(
Don’t get it. Get a different exhaust.
The tips I bought required no work.
