Any special instructions on removing the wind guard and bolts? Just a regular sized washer, and only one is necessary?Remove the wind guard. You will see two bolts in the front of the tracking for the sunroof. Remove them and gently pry up the tracking. Slip a metal washer under the track and replace bolts. This changes the sitting of the track and kills a lot of the noise. I did the glass raise first, it helps 80%, then the washers. She’s pretty quiet. Been about 6 months.
Thank you. I anxious to give this a try and be done with messing with it!
