Bronze chrome door trim
Trottzstinger
Can someone please tell me a gpod product to use on my 2020 stinger that has the bronze chrome trim around door.Mine has become very dull and i wanna know if anyone else is having this problem and what they used
Yep, the discoloration issue. Those pieces have been replaced by others under warranty. It seems to be a combination of weather/exposure and chemicals used to clean with. I've never used anything stronger than ONR and the occasional use of isopropyl alcohol if water and ONR won't remove a spot of contamination. A while back, I saw two, count 'em only two, what looked like hard water spots on my RR trim beside the hatch. Started with water; didn't touch them; went to alcohol and they were not phased; increased the ONR and the spots were still there; moved on to polishing compound and nothing doing; tried rubbing compound and finally the spots went; but so did the finish on that area: now it looks brighter than the dark chrome finish. Boo!
I have no idea what made those two spots; the only discoloration I've experienced so far on any trim. Others on here have buffed, polished, or otherwise cleaned their trim until it looks good again; and then sealed it or even applied ceramic coating. I think that a lot of exposure to hot sunlight is the main contributor over time.
Same issue on my 2019. Asked about it at the dealership during my recall and they said it’s not covered because it’s a chemical burn. Was bummed out about it so I did what people recommended doing, which was use Flitz metal polish. It worked, but now the trim is lighter than the original. Now I have to even it all out. FML...
Wow thanks for the help....the only issue iam having is the door trim all the other bronze chrome on mirriors front clip read hatch etc are perfect
I thought possibly like a quick detailer from like chemical guys or maguires would wipe this clean and shine it up for me.....it looks awful.I called dealership they said the detailer guy there has no idea what i can use becuase its not really chrome so fusterating
Easy solution
wrap it black.
Chemical guys "Light Metal Polish" or Maguires cleaner wax does the trick
Would you have a picture of the product you used....iam trying to google them and there is a few different products comimg up i dont wanna buy the wrong one
Yeah, that's why I stopped with the one spot. I see it. But I'm not ready to go over my entire trim and make it match a spot! Seriously. :rolleyes:
Wow thanks so much....have you tried this
Yes, I use the Light Metal Polish.... Where are you located?
Toronto - If you can get the 4oz bottle do it... they only had the 16oz when I bought it... (@ Detail Garage) probably last me a life time lol
you should go to a different dealer
be careful with the polish route as you are just taking off the outer surface. I believe the trim is similar to how they make black chrome or dark stainless (you're not polishing real metal). Other people have posted on here about compounds rubbing off the darker film on the outside and not liking the results.
I have ordered the chemical guys light metal polish so we see how that goes...thanks everyone for the fast replies
Stingers rule
View attachment 57176Its like Franks Red Hot Sauce , put this S--T on everything , best trick for water spots , bird poop , road tar and keeps your chrome clean and protected ...................
Looking at that reminds me that one of the first things I tried after ONR treated distilled water was the paste Meg's Cleaner Wax. How would these differ vis-a-vis the cleaning aspects? The two spots that I was trying to get off looked exactly like hard water spots; but the paste cleaner wax didn't phase it.
Voodoo ! don't know , seems to work on everything I come across
