ChaneRZ
1000 Posts Club!
Thanks man! I’m going for a HECU recall and I want to leave the intakes. Of course JB4 off. Goodluck on your car!I did, yes
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Yeah intakes won’t be a problem. Thanks brother!Thanks man! I’m going for a HECU recall and I want to leave the intakes. Of course JB4 off. Goodluck on your car!
That crossed my mind but I’m not sure that would apply. It’s not the fault of the car at this point, but flaws in the work. I love the car anyway, so I wouldn’t want to part with it.If it takes them three repairs to finally fix this... but it continues... might wanna look into a lemon lawyer...
Yes true. Well good luck!That crossed my mind but I’m not sure that would apply. It’s not the fault of the car at this point, but flaws in the work. I love the car anyway, so I wouldn’t want to part with it.
After visiting the dealer today, they are ordering a new radiator hose. Hopefully that fixes the problem for good.
I get the clicking too, replaced both front axles and it's still there also with a pretty bad vibration. It's a u-joint, wheel bearings, or prop/driveshaft support bearings IMO. Let me know what you find out.Heading back to the dealership in an hour or so to have a radiator hose replaced.
Also recently noticed a noise coming from the car. It’s a metallic clicking/chattering noise when coasting at low speeds. Noise is proportional to wheel speed, but definitely 4-5x faster than wheel speed (1 rotation of wheels does not equal 1 instance of the noise). Noise seems to go away as soon as I apply any throttle. Took all of the wheels off to make sure there were no rocks or anything wedged so where. Lifted the car and spun the wheels and couldn’t hear the sound. I’m thinking it’s mechanical. Something in the drivetrain, probably caused during the transmission replacement. I’m going to have them try to find it. Fingers crossed. Hopefully they do and it’s something simple.
I’m getting more and more motivated to let this car go and get a Vette
My noise, as I expected, is coming from the driveshaft (internally). I could tell it wasn’t coming from the front of the car. Also, I can’t feel it. I can only hear it. I hope you get yours figured out. I know first hand, it’s pretty upsetting.I get the clicking too, replaced both front axles and it's still there also with a pretty bad vibration. It's a u-joint, wheel bearings, or prop/driveshaft support bearings IMO. Let me know what you find out.
They opened a tech line case and I’ll have to drop the car off some time next week to have that figured out and fixed, as well as replace the rad hose.
Dealership never called me. Tried calling them yesterday and today, no answer. They’re closed now. I’ll call again on Monday and see what’s going on.Any updates?
I just notices I have a leaking transmission yesterday when I changed my oil. 4500 miles on my car. 2020 AWD GT2.
I have an appointment on the 24th.
Only mods were snorkels and JB4 on map 2 (Denso sparkplugs). Have noticed like a slight bit of “weirdness” in the car. Just hasn’t felt 100% and the of course the leak.
Does your state have a lemon law? If you do may want to contact a lawyer.an update: Took the car back in on 3/18. They gave me a K5 as a loaner. Had the upper rad hose replaced and the drive shaft replaced. Got it back on 3/24. Fixed the the noise. Coolant STILL has a slow leak. Its very slow, but its definitely not 100% fixed. I filled the radiator completely and the coolant reservoir to the full line on friday. It's near the low line now and the fill neck of the radiator is empty. I cant find the leak so I hope it's not a head gasket issue. No white smoke and nothing in the oil.
Very tired of going to the dealership and driving loaner cars. If I didn't just buy a house, this car would be gone. I've had too many issues with it.
It does but only qualifies for cars less than 1 year old and under 12,000 miles. Unfortunately I'm over 2 years and 32,000+ miles.Does your state have a lemon law? If you do may want to contact a lawyer.
I’m pretty sure. I kept filling the radiator and after 2 minutes, the neck was empty. Did that about 6 times before doing what I said above. I’ve driven it a couple hundred miles since I got it back, so it should be good by now, but it continues to go down.Are you sure that there just was not air getting worked out of the system? Lots of cars have very complex cooling systems and it can take time to get all the air out.
I sympathize with you, man.
I loved the Stinger but I was not looking forward to dealing with a dealership for my car. So I traded it in on a 2017 Camaro SS.
I am now on my second month of a loaner car. 2020 Telluride. Started with a rear main seal leak, fixed that then transmission leak. Finally got approval for new transmission, now we wait. On my third rental car, at least that is being provided but hardly a comparison to my Telluride.This is going to be long, so TLDR: found a transmission leak. Transmission was replaced under warranty and they gave me a loaner car. Stinger currently has a coolant leak and is back at the dealership.
Alright now the full story of how it went/is going dealing with Kia for a major warranty repair, for anyone else who will unfortunately have to do the same.
While I was changing my oil at 30,000 miles, I noticed a pretty significant transmission fluid leak appearing to be coming from the rear main seal.
Dec 22: Took the car into my local Kia dealer near Pittsburgh to have the leaked looked at, so Kia could decide what to do. I was informed that the tech who looked at the car confirmed that its leaking, and opened a techline case. Basically a warranty case with Kia. I was instructed to make an appointment after the holidays to follow up and have "further diagnostics" done so Kia could decide what to do. Also asked them to order the parts for the HECU recall.
Jan 3: talked to the service manager who set me up with an appointment on Jan 12th at 9am. I was under the impression that they would gather the info needed, and maybe check for a tune/any mods that might have caused the leak.
Jan 12: I got there and was told they would need to drop the engine to do their further diagnostics. They would send the info to kia who would approve the repair and only then would I be able to get a loaner car, This sounded pretty ridiculous to me because the job is half way done at that point. So I was told I could drop it off any day, any time.
Later that day, I returned with a ride home to drop off the car. At this point, I was under the impression that they'd be doing what they said, dropping the engine. Along with state inspection and the HECU recall, for which the parts had arrived.
Jan 14: Got a call informing me that they will be replacing the transmission. This is great because I was worried about any damage that may have been caused from low fluid. I was told I can pick the car up and they will call me when all of the parts arrive.
Went to pick up the car. They did the state inspection and the HECU recall fix. Engine and transmission were never touched. Not sure what happened to the "further diagnostics" they were going to do, but whatever. It's getting fixed. That's all I care about. I was also told a loaner car has been approved and they will be ready with one when I drop off the car, and I will be able to keep it for the length of the repair. The transmission replacement should take 2 or 3 days.
Jan 19: got a call. Parts were in. Made an apt fot the 27th. A loaner was approved from enterprise.
Jan 27: Dropped the car off. Someone from enterprise picked me up in the loner. Drove me back to enterprise where we did paperwork, and I went on my way.
Jan 30: got a call that the car was done. Went to pick it up. Let it warm up in the parking lot before leaving. All seemed fine. Got about 10 minutes away and the car starts overheating and steam is coming from the engine bay. Coolant leak. Great. Had to wait 2 and a half hours for a tow truck. Now the car is back at the dealership and won’t be touched again until Monday. Let’s hope they get it right this time. I had a feeling something wouldn’t be right when I got it back.
will update when there is news
Best of luck. I hope yours goes better than mine. My car still had a very slow coolant leak that I couldn’t find when I sold it. But the transmission itself was good and the leak never returned.Oh boy - just dropped mine off for the trans leak repair and they said they are going to have to RR engine and transmission to fix it. I am really uncomfortable about that and after reading this thread I am mad for you and frightened for my situation. This local dealership has the worst reputation around. Prayers for my 2019 GT2. Did you ever get it all worked out?
Wow!I feel your anxiety. I had my leaking transmission replaced under warranty ( R & R engine / trans ) but I got lucky and scored a good mechanic ( also I dropped in and saw it mid way and had a chat with the mechanic. Not that I want to induce any further anxiety but if you do go in to look mid way, expect to see something like this.
