STINGER
its worse, all cylinders are now misfiring
That orange coating on the plugs is from the boostane, it will cover everything in the cylinder all the way out the turbo. Boostane and the like are good at raising octane but they contain MMT which does reduce the plugs life. Anyways, it wont change your path to trail and error this issue out. You need to put new plugs and remove the Lap3 and run straight 93 to see if the issue goes away.
