The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Advertise with us!
Promo code: REDLINE
I don't recall that but I may be incorrect.Im sure the old firmware had the speed limit logo on the map flash when you are going faster.....
Am i missing something?
In old version the speed sign would change to red but never flashed , now in new version your actual car speed is above that..Im sure the old firmware had the speed limit logo on the map flash when you are going faster.....
And it will change to orange or red depending on your speed when approaching a fixed speed camera.In old version the speed sign would change to red but never flashed , now in new version your actual car speed is above that..
It does but sometimes the audio warning plays silly buggers. I’ve noticed at times it gives the voice warning of the speed camera ahead followed by beeps until you drop below the speed limit then the double beep/ding dong when you pass the camera. Other times there’s no voice warning just chimes prior to the camera and then the ding dong as you go past it. Same camera I drive past it every day going to and from work. I’ve noticed a bunch of little quirks with the system since the update.And it will change to orange or red depending on your speed when approaching a fixed speed camera.
Gremlins. This happens all the time to me on Waze as well.It does but sometimes the audio warning plays silly buggers. I’ve noticed at times it gives the voice warning of the speed camera ahead followed by beeps until you drop below the speed limit then the double beep/ding dong when you pass the camera. Other times there’s no voice warning just chimes prior to the camera and then the ding dong as you go past it. Same camera I drive past it every day going to and from work. I’ve noticed a bunch of little quirks with the system since the update.
Your right it changed color when speeding.In old version the speed sign would change to red but never flashed , now in new version your actual car speed is above that..
I'm still not sure what you mean.After update, the actual speed of the car is shown on the display positioned over (above) the speed limit sign that is displayed (and changes color if the actual speed exceeds the posted speed limit).
~3kph variance is normal.Thanks for that, I now have it turned on and changed the arrow color.
I'm seeing a 3kmh difference.
Anyone else?
