Snowwhite
Sustaining Member
- Feb 3, 2020
The rear sway is nowhere near the exhaust. Unless he dropped the rear subframe to put it in and didn’t tighten up the exhaust after that, there’s no way a rear sway would cause drone. You would have paid a lot of labor if he did it that route. I installed mine without dropping the rear subframe.
I had the exhaust removed to install an aftermarket exhaust, and when I reinstalled the stock exhaust there was no drone afterwards.
you got a module that stiffens the shocks, but you’re looking at the rear sway as the culprit for a rough ride now? Don’t you think you should investigate the mando unit? Many others have swapped out just the rear bar without the effects you’re reporting.
I assure you, no sway bar will affect idle quality. Now if that mando unit is screwing with voltage on a computer power circuit or signal line, that could cause what you’re seeing. I would remove the mando and leave the sway bar be until you go for a few drives with just the bar.
The only noises a sway bar can make are squeaks or clanks.
