Confirmed today in the rain, traction control does NOT work. Now with this being said I believe traction control is also used for stability control so I think its safe to say that won't work either.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
My first few cars didn't have any TCS or stability control and I never crashed any of them.
But then again none of them were rear wheel drive, and the most powerful one had about 164hp.
I could swear I see a difference with TC on and TC off. Its by no mean as good as awd, but I can smoke the tire easy with it off. I will have to double check again tomorrow. And stability control definitely works, the car is a handful when its off.
I am going to revisit this, studying document after document this is something that KMA (Kia Motors America) refuses to publish other than subtle hints about making this car RWD.
I've looked at the AWD system and how the canbus communicates with the AWD system. This fuse in only live, under 60KPH. The entire front end of this car, is turned off and we do indeed have 200lbs or hurling axles, and a front diff just spinning and not doing anything, this is the main reason why we have no CEL. or error codes on the dash. Zero power to the front end over 60MPH. By removing this fuse, in theory the car decouples the clutch and there is ZERO chance of it engaging. I would like to put this car on rollers and a multmeter showing when power is applied to this circuit and study it a bit more. Seems like a simply fuse tap/relay switch to convert AWD to RWD.
Why? I am going to put a LSD (Limited Slip Differential) in mine, and one day have the ability to go RWD at the track.
Did you ever end up testing this further? I would be very interesting in an LSD (Limited Slip Differential) as well for this car.
So I actually just got off the phone with a Kia dealer who looked up parts for me. Apparently my 2020 AWD GT2 is mechanically the same as the 2020 GTS, but has different ECU/TCU programming. The parts guy said that essentially the only difference is an electric shut off for that AWD fuse. I'm not sure the difference in torque vectoring vs whatever the GTS uses to know if literally pulling the AWD fuse is the same as drift mode in the GTS
Technology is totally different. I was skeptical coming from the Subaru community.My little brother and i had dsm's in highschool
I had a fwd tsi talon 2g he had an awd eclipse gsx 1g
We had fun but one day he was unsupervised and removed his 2 front axles to 'make the car rear wheel drive'
It ruined the center diff and trans from obvious missing parts.
Yes very different circumstances but i do not want to see stingers with melted center diffs or anything like that so there i said it.
this gives you 100% to the rear wheels ?
But this is exactly what the GTS does. With the same components. The rear axle / diff are the same as the RWD versions save for those with LSD.I really wouldn't do this knowing that what people will try after taking the fuse out.
AWD components aren't designed to handle 100% power at rear.
