Marc Collins
1000 Posts Club!
Google translate.
Hello everyone. Today I will tell you how to fix the hated creak of the hatch on the passenger side that occurs when it is closed. The method I found is still experimental and not a fact that will help you too, but it helped me - now I am happy as an elephant!
1. Open the hatch completely
2. It is necessary to remove the plastic trim on the passenger side, marked on the photo
Full size
It is held by three latches and can be easily removed even with your hands, without a screwdriver. Do not break
Full size
3. Close the hatch halfway.
4. Loosen the front hatch bolt with a Torx T25 bat.
Full size
5. Close the hatch, then open the hatch to the end.
You will see how the loose fastener shifts during the opening process, as the bolt is not tightened.
6. Tighten the Torx T25 bolt back when the hatch is in the fully open position.
7. Close the hatch and check for creaking on bumps.
It helped me Apparently, the joint is due to a slight skew of the hatch when it was mounted at the factory. If this does not help, just loosen the front mounting bolt or even unscrew it completely, but a play may appear. Hope that helps you too. Unsubscribe about the results!
Will try this and report back after the first time my car is parked out in the sun for a while (which is not very often). It's always after that expansion/contraction process that the creaking is the worst.
Others please also do the same! It will be truly awesome if this works for all or even most.
		 How to help people after all that...
