Took it in finally today to my local Kia and they untightened a few bolts that seemed to create alot of the noise and sprayed some silicone or whatever their warranty manual bulletin thingie tells them to do. That seemed to work for most part, one of the gaskets(?) was messed up and is gonna be replaced under warranty in a few weeks. When driving the remaining slight noise that came seemed to come pretty much from the area of the gasket so hopefully once that is changed the fix would be final.
I also gave them the link to this topic and they got quite a few ideas to try out incase this does not work, unfortunately because it is not under warranty in normal circumstances, they cannot do it quite free of charge. The same dealership also sells Opels (Vauxhall) and Cadillacs and said that it is very odd that the warranty manual for Kia only gives them the instruction to spray the rails or whatever if creaking does happen to exist. Everything else goes under the point of "quiet noise or vibration that does not affect the quality of driving or using the car" and is not covered by warranty.
