Has anyone added tips to the Ark exhaust? I plan on doing the oval tips. 63mm / 105mm?
I am also looking for 63x105x75 stainless tips... all I can find online in this size, are all black/carbon fiber/matte black.
Also searched this thread and didn't see any links or references to stainless tips.
I may have to go with the black ones. I found with the 2" tip on the Ark exhaust I would need 51mm inlet and 105mm outlet.
Did you have to cut the bumper or was removing the stock tips enough room ? They look great !!!
Has anyone got an ebay / aliexpress link to the Akrapovic tips where you can choose the size you need? One page for all different sizes available
It has been 6 weeks since I have ordered my tips from Aliexpress. June 10 is the time I am going to open a dispute for a refund. It sucks I was looking forward to putting some on.
If you mean welding to the existing factory exhaust tips, then my weld guy said that they would melt probably. But nevertheless today (probably) we are looking into whether it could be an option because currently I have the low rpm low speed muffler delete reverberation issue that needs fixing. Most probably though will either source some stainless steel tips locally (cause its faster) or order Akrapovic style from Aliexpress.Has anyone had success in minimizing drone by just weld tips onto the existing pipes? My xforce fits about 20mm Into the existing factory tips at the moment would you suggest extending them say 100mm into the existing end pipes?
Anyone have a working link besides these? Looking between vendors to see shipping and price cost differences.US $28.7 18% OFF|Car styling Oval Slanted Ak ra povic Exhaust Tip Glossy Carbon Fiber muffler Exhaust tip muffler pipe Tailpipe trims|Exhaust & Exhaust Systems| - AliExpress are the ones I used, Size A out was perfect, I got 51 in that perfectly fit my Borla. Was a SUPER simple install, definitely worth it and gets a ton of great feedback at local events.
I have a 2.5" exhaust pipe (63.5mm) so what size would be the best from the oval ones so that its' a perfect fit or requires as little trimming as possible?e
you had to take off the bumper or can the tips be slid off? if the bumper comes off, there is no electronic components in the bumper to look out for?are the ones I used, Size A out was perfect, I got 51 in that perfectly fit my Borla. Was a SUPER simple install, definitely worth it and gets a ton of great feedback at local events.
