How was your experience with them? is the car faster?
The car is tremendously faster and more responsive than anything I would have ever expected with a
3.3TT. I used to have a 2007 dodge magnum srt8 (6.1L hemi) with CAI and diablo tune and this blows it away - that's the first time I've ever wanted to admit that about any other vehicle. Whether I'm stopped or in motion, the car roars to life. Minimal turbo lag and monster boost that is both constant and smooth across the power range. I've been on Continental ExtremeContact Sports for about a year and I clearly need to replace and/or upgrade them in order to hook because the response is so damn quick. What Terry is developing feels like an adrenaline shot on steroids. Anyone that craves being thrown into the back of their
seat (aka all of us) should keep an eye on this.
I would be curious to know as well how you fair with it ?
which map are you using ?
Now this is where it gets interesting. I run an e30 blend with 93 and no more than 5gal of e85. The first time I got everything to work correctly, I started with map0. When I switched to map1, I instantly knew something special was happening. After a few WOT runs, I progressed to map2 and the difference was so much more than I was expecting. WOT a couple more times and then map3. I thought I was prepared for it, but wrong again. Then I realized I had been in comfort mode the entire time... Switching to sport at that moment felt like riding an angry unicorn. Literally speaking, I'm not prepared for map4 and haven't used launch mode at all. Safety first, then new tires, and finally proper fuel before the next magic carpet ride... I've been using map3 with e30 as my daily driver long before
EWG, but I'm in no rush to wear out this thrill anytime soon.
For anyone interested, I've merely added BMS intakes along with the
fuel wires for the JB4 (
densos). This is completely by design because Terry has made everything crazy easy to remove in case I have to go in for any warranty work (same reason I sprang for his OCC). Thankfully, I haven't had any reason to bring it to the dealership - but I'm not willing to take any chances. And as for exhaust, I love a quiet cabin - but show me a system that has absolutely zero drone and I'll trade you my amazing flea circus.
Would you mind sharing what user settings and firmware you have? I am simply going off the recommendations from this thread. Still happy with the performance so for but if there can be more...
This might bring some people back down to earth. After finishing the physical install (simple, 30 min), I made a firmware jump from 13 to 16 and, in user adjustments, set duty bias to 50 all the way down, FF to 50, PID gain to 20, and Auto Shift Reduction to 60. This didn't yield the intended results as my first test run had no throttle response, boost, or anything that even resembled my stock engine. Nothing changed after flashing down to 14 except for some undefined code which I immediately cleared and hasn't returned. So I decided to throw in the towel by updating to 15 so I could use bit5 to deactivate the
EWG system. Now I'm not sure what bit5 is supposed to be labeled, and I can't recall at the moment what it says in my app, but it's not exactly an apparent
EWG on/off switch. As noted earlier, however, I'm using the beta version of the JB4 app on my pixel 4xl - but I'm not sure if that has anything to do with my situation. Anyways, without knowing how to turn it off, I left for the post office to mail a dirty diaper to Terry. Before pulling out of the driveway, however, I changed FF to 60 and tried bit3 in the WMI menu (still using v15). After that, I decided it was best to pass the post office because it's too dangerous to stop when you've hit ludicrous speed.
Due to the foregoing issues I had with the app/firmware, I haven't updated beyond 15.
