Interesting. So are you suggesting that replacing the midpipes would give you more high end power at the cost of low end? So a net zero increase, but a shift in where the power is? And a cat back will give better low end performance? I wonder what the physics is behind that. Both are increasing airflow. And thanks for the data driven response!@Mr. Tech I've got empirical data. Several dyno plots showing the power difference. And I'm just like you (intakes and JB4...and colder plugs). If low end "grunt" is your goal, you don't want secondary pipes. IATs are important, but only for back to back runs. You'll net more power with cat back exhaust than pipes.
