The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Ok. Before, I will try v15Turn on options bit0, or just disconnect the AFR wires fro the posi-taps and tuck them out of the way.
Ok here it is Terry. V15 Map 1 first, then Map 0, and Map 2 (let me know if map 2 is ok please thank you)No since the run is basically in limp mode so it's not making normal boost.
So this is with tightening the fuel wire tap both ends on driver side. Didnt drive more then 30min but i havnt seen the Code P061B come back yet
PS: i also noticed every first time i change maps, it reverts back to map 1 everytime. So i always have to apply it twice. (did this on v14 as well)
great...Map 2 seem ok? If it is i'm gonna continue on that one. I'll keep this thread updated incase others have similar issues.Log looks normal so keep on trucking!
did you have time to try v15?Yeah that's very weird we both did installs pretty much same time. I will update firmware now to v15 and go for a run on map 1 and map 0
Map1 + V15 beta
I tried 2 runs of 45 minutes without CEL.
At this moment it's ok
Another question about log. Is it normal that i see false peaks since boost signal. Check this picture
i will take pictures in 1 hourI have a suspicion this fault might be related to an issue with the JB4 mobile adapters themselves. Photo of your adapter and where it's located in the engine bay?
Here is the pic. So i drove today for 45min This is what happened. No code so thats good. I started on map 2 (turned off my car previously on this). It stayed on map 2 for about 15min. After that it suddenly without me doing anything changed to Map 1 and stayed on Map 1I have a suspicion this fault might be related to an issue with the JB4 mobile adapters themselves. Photo of your adapter and where it's located in the engine bay?
Any advice on my previous post? about the map switching 2 to 1 by itself?As a test try removing the black shell on the JB4 mobile adapter that attaches to the JB4 board, I wonder if that might be preventing a solid connection to the adapter.
I will check the connection between the mobile jb4 and the jb4 module at this week end. If after checking the connection and the problem is still present, will you send me a new mobile bluethoot jb4 ?As a test try removing the black shell on the JB4 mobile adapter that attaches to the JB4 board, I wonder if that might be preventing a solid connection to the adapter.
Ok thank you. Good job. I appreciate the speed of your responses !It's an evolving issue so we're trying to figure out if all of the new JB4 mobile adapters are physically faulty, if there is a firmware issue with them, or if there is some other issue like the connector not allowing a proper fit to the JB4 control board.
Meanwhile I'm working on firmware v15.1 I'll post later for you guys to test trying to patch the issue on the JB4 side.
sounds good thanks Terry. I am also going to test if it is a bluetooth/app issue by setting the map, making sure its set to 2, and then closing the app disconnecting BT completely to see if it decides to change on its own again. THat should tell us if its on hte jb4 side or BT/app side.It's an evolving issue so we're trying to figure out if all of the new JB4 mobile adapters are physically faulty, if there is a firmware issue with them, or if there is some other issue like the connector not allowing a proper fit to the JB4 control board.
