The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Advertise with us!
Promo code: REDLINE
Anyone have a link that they’ve recently received an order from? I just had to cancel mine. Seller kept telling me “just a few more days to ship”... I don’t think I’ll ever get them.
Same here. Anyone have a good source for tips? Looking for round, black or CF, with the blue lip. Ordered a set of Ali a month ago, supposed to ship last Friday, and now it says they'll ship in 13 days. No response from vendor after three messages.
Why are so many people getting 89mm outlet round tips when 105mm oval tips fit without trimming?
Aesthetics. The round tips look more aggressive and provide a different look.
And trimming sounds quite involved. I filed a bit on top and bottom with a metal file until they fit and that’s all it took.
Hey guys,
Can I ask who your sellers were?
I just placed an order on Ali Express so I am hoping that I will be getting mine next month.
That’s all the trimming you needed to fit the round 89mm tips? Please provide a pic. Are these connected to and aftermarket exhaust?
I agree that I like the look of round better.
The reason I'm requesting pics is because I took my car to an auto body shop yesterday (I have the round 51X89mm Akrapovic tips) and they said it looks like the lower half of the diffuser would need to be removed to accommodate. They are seeing what can be done and will be getting back to me. I'm wanting to attach these tips to the tail pipe to extend the exhaust behind the diffuser to reduce drone as well. I want to make room for movement of the tips given that they will be connected directly to the tail pipes of the Borla exhaust and there will be some movement of the exhaust over rough roads and bumps. You mentioned the tip fit is very snug with minimal trimming of the diffuser, and my concern with that is that rubbing, vibration, sound may occur between the tip and the diffuser. Please report back if you run into this.
Did you attach these tips to the diffuser using a bracket similar to what is attached to the OEM tips? In regards to your MBPR tail pipes were the centered within the OEM tips prior to installing the Akrapovic tips? The reason I ask is because my Borla tips cannot be centered given the distance between the tail pipes and the distance between the OEM tips, therefore this will require additional trimming of the diffuser to make them fit. I like the look of the round better than the oval, however the oval are an exact match, so I may go that route. The downside with that, is I will need to order from China and with the Coronavirus causing massive delays with shipping I may not get these tips for months. Maybe I can get lucky and find a local seller.
What’s the linkGuys, check Amazon. I just got mine on Prime 2 weeks ago.
The ones I ordered did not show the Akrapovic name on the tips, however when they arrived it was there (bonus!). Just search 63mm 89mm exhaust tips, or whatever the desired size is.
I cannot link from the amazon app on my phone.What’s the link
Anyone who plans to run their aftermarket exhaust with the secondary cat deletes (midpipes) i highly recommend going with the oval exhaust tips rather than the round ones. I recently swapped round for oval and all of the rasp I was getting on cold starts is now completely gone.
I think the lack of secondaries causes more shake in the exhaust and if you have the round tips installed that are tight in the diffuser, this creates vibration as the tips shake inside the diffuser which creates a raspy metallic sound. Some get it at certain RPM's, others at cold start (me).
I'm completely happy with my MBRP + SSR Midpipe setup now.
What size oval exhaust tips did you purchase?
54 in, 75 od & 105?
63 x 75 x 105
If I’m in the market for custom made exhaust tips any of those dimensions you would adjust after installing that set?
