turboAWD
1000 Posts Club!
I discovered a cool feature in the engine bay. if you drop a plastic trim clip or a small wrench in there, it ends up in another dimension. 3 plastic clips were lost, never to be seen again. 7mm wrench ended up on the frame in a spot behind the front right wheel. Took me an hour to find and another hour to fetch![]()
Yeah - lost an 8mm or 10mm socket when doing plugs. Spent 30 minutes with a mag tool, but no luck. Thankfully, sockets are cheap
