I’m not sure what you mean.
KIA/HYUNDAI has been using the same harness for at least 4 years. I can confirm fitment, not only on the Stinger GT and GT2, but also my 2017 Elantra Sport, 2018 Sonata Sport 2.0T, and my wife’s 2020
Telluride EX.
Simply pull the mirror and see how many pins are in the harness. It will have a 10 pin harness but only 6 wires, at most, are being used on the upper trim models, which makes sense if you unplug the mirror and look at the connector, you’ll see only 6 pins so the harness not including those pins is irrelevant, which also means the wiring is going to be fairly consistent. The frameless mirror will 5 wires being used thanks to the exclusion of 12v constant in an attempt to prevent Homelink burglaries.
This isn’t anything new or particular to the Stinger. OEM mirrors are used across a range of different vehicle manufacturers. The same mirror I’m using is a PNP mirror for the Toyota Tundra as well and the pins are an exact match.
In summary, the OEM mirror in the Stinger is not specific to the Stinger or even KIA. It is used in several other vehicles. Find the correct model mirror and it’s a PNP job.
If your model didn’t come with Homelink or didn’t auto-dim, check your harness — if you see 6 wires then your car is pre-wired, you just didn’t have the mirror to take advantage so it’ll be PNP once you get the new mirror on. If you don’t have 6 wires then you’ll need to run accessory to the new mirror, which is also very easy to do.
It would not be surprising if all the cars had the same wiring but the mirror itself is what provided the additional “features”. Swap the mirror and gain the features, but we’ll see when someone who didn’t originally have Homelink comes along.
