The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
Yeah hit 26 psi this morning!Good to hear. I'm really loving the new EWG control now that I mostly have it working. That combined with the new boost scaling means we'll probably see some 25psi logs soon lol. Don't think there is much more power to be had beyond "20psi" with the new scaling but never hurts to keep trying.
That is my long term plan. I hope I can still use JB4 with a back end flash on hybrid turbos.EWG opens up a lot of possibilities, especially so for larger turbos!
26Yeah hit 26 psi this morning!
On the new scale i think 22-24 still has some added power.
Do you have a theory to explain the higher torque at 20psi?Collected a little data today... Found a problem in the firmware and didn't have the software handy to fix it so will need to pick it back up later. But, so far the data mirrors my previous testing.
1) Boost > 20psi, minimal gains. Especially top end boost where we need it for track benefits.
2) Leaning out AFR does add top end power at the expense of stability/safety.
20psi vs. 23psi peak:
23psi peak but with a much leaner AFR (like, 14:1 at peak HP!)
View attachment 36353 View attachment 36354
What Map are these tests done on?Collected a little data today... Found a problem in the firmware and didn't have the software handy to fix it so will need to pick it back up later. But, so far the data mirrors my previous testing.
But at 6000 you have 15 timing in both and a few more PSI in one and the HP and TQ are the same which is odd.
Thanks for sharing, great info and exciting how much boost you can hold at RPM now.
Do you know if the wastegates are open during launch control? I wonder if we could build a little boost if they're fully closed we could actually do some brake boosting in LC...?
How is your test car on the exhaust side? Is it stock?
Could it be heat as well? 22 psi at 6k is alot more turbine speed than 22 psi at 4k.
Timing is good at 6k.
Can you share graphs showing boost and share csv? Something looks to be restricting the top end... One thing that I don't get is your showing numbers now that don't agree with you jb4 site...
Would there be any increases for users who are only using Map 1 or Map 2?Map6 and the E85 autotuning map. Running car on 40% E85. Ran CPI to keep fuel pressure level as boost went up on these specific runs but on another round of testing where I test it leaner (the 465 chart) CPI was disabled.
That would make sense. Can't it also be the exhaust getting too hot?I outlined my theory in another post but basically excessive back pressure preventing top end gains is my suspicion. Likely, due to the small factory turbine. Catless primaries may extend the top end power band a bit in this situation.
