Scott Curry
- Oct 25, 2019
Yeah that was plugged in, but does the engine have to be turned off? I'm gathering it does that is how it an external obe code reader works you don't turn the vehicle on you just put it to the accessories I'm sure this probably works the same way can't read the codes unless it's an accessories and not turned on.
stock plugs would have worked fine gapped properly.
