lun471k
Dumb question of the day: Do you need the OBD2 add-on cable to get these logs for Terry ?
Second dumb question of the day: Is that the "BMS Data Cable" option when purchasing a JB4, or do all JB4 have the OBDII connector by default?Yes most of the good stuff comes from the OBDII cable/CANbus.
Don't worry about me bud, .024 is just a suggestion. I GAPPED AT .024 and would GAP .024 again.
There is absolutely nothing wrong gapping at .024 MR EXPERT !
Edit to add--> My factory OEM plug gaps ran from .032-.036. That's a problem...
How many have had problems gapping Densos to .024? None
I gapped at .024 and am second guessing myself. Was on my to do to regap to .022. Perhaps I'll relax about it.Agreed. I think you are good. I don’t think .002 makes a difference. I think stock plugs are gapped way higher anyway. Correct me if I’m wrong someone. From the various post I have read, people are gapping from .020-.028 .024 seems pretty reasonable.
Please understand this is nothing personal and just trying to help.Don't worry about me bud, .022 is just a suggestion. I GAPPED AT .024 and would GAP .024 again.
None !
There was a lot of angry typing yesterday.
Very nice and impressive results, especially with stock catback exhaust.Got on a dyno to see what numbers I get.
I had "only" 439ps last spring with JB4 and WMI on my otherwise stock car but my settings were far from optimal.
Same dyno, 6 months later
-> Best run : 494ps 70kg.m (= 487hp 504lb.ft)
Map8, 83% ethanol, BM7 nozzle (700cc).
They turned off my car and the bluetooth connection expired so I don't have logs of the 4 pulls (feeling so stupid..).
I still have the stock exhaust on, so I hope to break 500 next spring after I make improvements.
FYI, AFR does not exceed 11.7 and no TDC fooling.
I am really curious about the drop at 6.2K RPM.Peak numbers look good! bummer on the logs, if for nothing else to see if it has any more power in it.
