Nasscar
2500 Posts Club!
My Stinger is my daily driver, I try to get it under cover on my day shifts and keep it away from the trees that hang over the uncovered parking spaces. Night shift isn’t usually an issue getting a covered spot, but it’s only ever partially covered, if I nose in, the back end is still exposed but it’s better than all of it. Still gets covered in dust and lately pollen even when under cover. The only truly covered spots are on the lower level car parks but they’re reserved for the work cars and the bosses. Middle management like me don’t get the luxury of the basement car park. That being said the basement is a bit tight for maneuvering and more risk of someone rubbing against or scratching while trying to get into a work car so there’s pros and cons to each I guess.
Yes that dust and pollen is a killer. Need to wash your car everyday to keep it clean. I am spoilt being able to use a daily driver to keep the Stinger home safe and clean. I feel for you guys that use it as a daily driver.My Stinger is my daily driver, I try to get it under cover on my day shifts and keep it away from the trees that hang over the uncovered parking spaces. Night shift isn’t usually an issue getting a covered spot, but it’s only ever partially covered, if I nose in, the back end is still exposed but it’s better than all of it. Still gets covered in dust and lately pollen even when under cover. The only truly covered spots are on the lower level car parks but they’re reserved for the work cars and the bosses. Middle management like me don’t get the luxury of the basement car park. That being said the basement is a bit tight for maneuvering and more risk of someone rubbing against or scratching while trying to get into a work car so there’s pros and cons to each I guess.
