Hey are you racing today? Daegu?OK I guess I have to give it a try! Thanks for the feedback
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Advertise with us!
Promo code: REDLINE
No I didn't apply for it. Are you?Hey are you racing today? Daegu?
Yes!No I didn't apply for it. Are you?
Cool! what are your spec?Yes!
I did almost the same , got the Eibach springs and also the rear sway bar and of course a wheel alignmentIt was $324 CDN plus 3.5 hrs labour. Total $750 CDN. In the US the kit is $275 or so. The 3.5 hrs labour will still apply. NO BRAINER!
In case someone misses it:
Check this out!!! (ECS control module)
Sways and springs are pointless unless your regularly hard core tracking or just want a lowered car.
So could I before the ECS
All those things are fixes fire poor or inadequate suspension tuning. Most of which, in this car at least, are down to damper tuning. The ECS corrects for that, therefore sways aren’t needed.
If you remove the shocks entirely, the car will roll like a drunken pig. If you replace the shocks with solid bars, it will not roll at all.... I don't believe the ECS tuning will reduce body roll.
Sway bars are a bandaid fix for poor damper tuning. Not only that but the more sway bar you add the less independent your suspension. So if you like the idea of being closer to a solid axle suspension so be it.
You say until someone shows otherwise. Well I’m showing otherwise. I’ve modified over 15 of my own cars (all types) with springs, sways, etc over the past 30 years, and this easy replicates what they do at lower overall cost and easy installation and way more flexibility.
This device allows you to tune the suspension to your own liking without having to spend lots of money, and it’s customizable to achieve all the things you are after. Why anyone would want to use a fixed option lower tech solution when a better one exists is beyond me. But hey it’s your car all I know is I’m glad I waited.
Whatever complex of parts/factors produces poor or good handling: you can't simply say one of those parts/factors is a "bandaid". Start removing "bandaids" and you'll "bleed".Sway bars are a bandaid fix for poor damper tuning.
ECU (ECS? what's the difference?)?
I think it's reasonable to say that stiffening up the shocks will reduce body roll.
That is different from saying that stiffening the shocks will NOT affect body roll.I don't agree, the spring has way more effect on body roll than the shock.
I also have the Eibach springs and both front and rear sway bar s , front was just put before my last track day and for me personally it made a difference and kept the car more stable, and my sway bars are set to MaxI don't agree, the spring has way more effect on body roll than the shock. The shocks purpose is to provide compression damping on the side of the car that the spring is compressing on, and rebound damping on the side the is decompressing. Basically the shock is there to keep the spring under control and damped the right amount. Stiffer springs reduce body roll and if you use springs that lower the car and reduce the center of gravity that has an effect as well.
If what you guys are saying is true, then everything people have been doing for many years in regards to suspension tuning has been wrong. In all my years of being a sporty car enthusiast suspension tuning has been mainly springs, shocks and sway bars. Some people even mess with bushings.
Sorry I just don't buy that all the tuning issues on this car can be solved entirely with shock adjustments. I own the sway bars and they help a great deal.
I have front and rear eibachs, stock springs, and I just put in the ECS over the weekend. That combo works very well for me. My sways are set to comfort and I have the ECS set on sport mode (have not attempted the customization options yet) and there is definitely improvement. When I say improvement I would say; 1. When I go from a complete stop to pull pretty hard, there is no hop. This was the case on the exact same road without the ECS. 2. When I hit the dips and such I feel the car get back "inline" quicker. 3. I believe using the customization of the tool will help me to firm it up even more to my liking.
For me; with the 2-3 days (50-60 miles) of driving I'm happy with the purchase. I will always say, it all depends upon your expectations. This is a computer adjustment tool and not a physical hardware upgrade (sway bar, shocks, etc) so it's only going to do so much. If you are thinking this will solve all your suspension "issues" or what you feel is an issue...you'll want to possibly rethink that.
