glad to see there is a post about this already the rotors on the GT are deff not from Brembo (its not the pads its the rotors) I smoked my rotors recently during a very high speed run I wont go into details for the fact of trolls. But a warning to all if you slow down from anything above 120mph you WILL over heat the rotors and they will turn to jelly and you might as well kiss them goodbye. the rotors where fine on my car under normal to hard braking at normal speeds soon as I needed the Brembos at higher speeds they failed horribly bad I had to use the transmission to slow down good thing I have experience or this would of turned out real bad. I love the car so much but the last thing I though would fail on me where my brake rotors. KIA will understandably not cover them and that's with me knowing the the service manager very well and personally , so I'm left to find
aftermarket drilled and slotted the hunt begins this can not happen to me again.
