itguy61
Khartunerz had them. I think the EOM replacements are the Gyrodisc, Stoptech and Centric pads.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Advertise with us!
Promo code: REDLINE
Whether this issue manifests is highly dependent on driving style, roads used, etc. The pads and rotors are the same on all USDM Stinger GTs. If someone does not have the issue, they don't drive aggressively enough or on challenging enough roads to heat up the brakes sufficiently. If I went and drove their car, guaranteed I could get pad deposits on the rotors within an hour..
Just kind of tiring reading about bedding brakes and driving aggressive when I have had so many cars with no issue including another one of this exact same car so no bedding brakes and aggressive driving are not the solution. fake news
I have two stingers a 2018 black GT2 and a 2019 red GT1. I bought the GT1 in March it is the one with the brake issues. … The pulsing is going to come back. I think it's the calipers not the rotors/pads
It's weird that the newer of the two cars has the poor feeling brakes. Is it possible that Kia is still getting the OE pads without having done a damned thing to address the depositing incidence? I don't suspect the calipers. From all that has been shared here, I still suspect a crappy set of pads. And if it were my issue, I'd try an aftermarket set.I would ignore the posts you are tired of reading about, don't let it bother you. Others including myself have had this issue repeatedly and as of right now the vast majority of the evidence points to pad compound putting deposits on rotors and causing vibration. If you are having a different issue I hope you are able to resolve it easily!
In case there may be a relationship with the point(s) of this thread -
I haven't really found any good information on specifically how the EPB (Electronic Parking Brake) system works on a GT2. Is the electronic parking brake actually a part of the Brembo brakes? The owner's manual mentions that when EPB (Electronic Parking Brake) is applied or released, "you may hear the whine of the parking brake electric motor", so wherever it is and whatever it does, apparently it is not operated by precisely the same process that the brake pedal uses?
How does Auto Hold play into this (if at all)? Does AH use the brakes, EPB (Electronic Parking Brake), or transmission to hold the car in place? If you are using AH does this really wind up doing the same thing as getting the brakes hot, then pulling up to a stop light, pressing on the brake pedal and holding the car and creating the problems described in this thread? Instinctively it feels like activating the AH by stopping and 'firmly' pressing the brake pedal enables AH and when you lift your braking foot, nothing happens - as though AH was continuing to hold the brake system just as though your foot was still pressing on the pedal, using the same brake process and thereby doing what this thread says, don't do?
Can someone explain these two systems in detail (the OM certainly does not), or point me to the information. Thanks
I dithered between "Informative" and "Winner".The EPB (Electronic Parking Brake) is completely separate from the AH.
The EPB (Electronic Parking Brake) is electric and holds the 2 rear wheels stopped using drums inside the rear disks.
The AH feature is as you describe - piggy backed onto the hydraulic system and simulates you pressing the brake pedal and holding. The AH feature is the same system that will apply the brakes for you when you have smart cruise control activated and the car in front of you decelerates (Hydraulic - same as pressing the brake pedal, all 4 brakes are applied).
The EPB (Electronic Parking Brake) actuator is circled in this attached image. Nothing to do with the Brembo calipers
Super!Additionally...
#16 here - (on the 2nd image) - is the actuator circled in the image I posted in post #310.
xxxxx (I'm not able to post a link?)
If you ctrl+F - PN xxxxxxx that is the actuator (#16 for the brembo parts list) - the SECOND image from this site.
https://www.automobilemag.com/news/2018-kia-stinger-gt-long-term-test-update-2/
Look towards the middle of the article. A test driver had the warped brakes issue at 11,000 miles. He called Kia and they said they were aware of the issue. Hmmm...
I'm not buying the "warped" diagnosis. The rotor must be on crooked so it wobbles.Same issue here. Told the service technician that the online forum was leaning towards pad residue causing the pulsing/vibrating. He said the rotors were in fact warped (6000 miles on car) based on measuring the displacement or some such. I forget the exact measurement number that he mentioned, but he said it was borderline between cutting/resurfacing and replacing, so he called the Kia tech line for approval to replace them. They OK'ed full replacement based on the measurement that he gave them.
He said that this has been common with Stinger rotors and the times that he cut rather than replaced them, the problem has sometimes come back for some owners. TBD how the replaced rotors feel next week. I'll definitely be bedding them this time though, which hopefully will decrease the chances of this issue reoccurring.
