Nothing ground breaking, but its a PR for me...
12.34 @ 115 1.95 60' running map 5 with 260GT Plus. DA was somewhere around 1500.
On my first pass I ran in map 1 on 93 pump gas to try and get a baseline, but I guess I was heatsoaked because I had a terrible run...
13.3 @ 107 2.1 60'
Intake temps reading on the jb4 were 174 at the line. I'm assuming that's what did me in?
Nice run without the snip! Looking forward to more and more people getting to the track.I couple new records tonight from Pacific Raceways. @TorkMe moves from #10 to #4 hits a 11.711 @ 120.51 with a 1.909 60 foot, unsnipped. Looks like Tork has a good chance to take the top spot with some launch improvements - on stock wheels and tires currently.
I dropped to a 11.800 @ 116.47 with a 1.74 60 foot using the BMS Snip.
Here are the top 15 track times as of July 25th, 2019.
1/4 Drag strip Top 15 times (Official Track List)
1/4 mile time, speed, 1/8 mile time, speed, 60
1. 11.548 @ 122.05, @Crewdawg130, 7.49 @95.66, 1.719
GT2 RWD, Hybrid turbo, JB4, WMI, FFP intakes, Ultimate HFC primary and secondary, FMIC, Drag radials, BMS brake snip.
2. 11.599 @ 118.77, @Kato_the_kia_stinger 7.464 @93.86, 1.614
AWD, JB4 map8, K&N intake, VT snorkel, WMI, 93 octane, BMS brake snip
3. 11.633 @ 120.83, @ScottyCole, 7.508 @94.00, 1.625
GT1 AWD, Lap3 Pro, K&N Intakes, Lap3 HFC, Ark Mid, Borla Catback, UP FMIC, WMI, BMS brake snip, 93 octane
4. 11.711 @120.51, @TorkMe, 7.620 @95.61, 1.909
GT RWD, Tork ECU tune, Tork intake, muffler delete, no cats, fmic. 92/100 octane mix
5. 11.764 @116.79, @Angel, 7.542@92.18, 1.608
AWD, JB4 Map 5, AP Intakes, SSR Downpipes, SSR Muffler Deletes, Tork OCC, BMS brake snip
6. 11.800 @ 116.47, @Tonkabob, 7.589 @ 92.89, 1.74
GT2 AWD, Tork ECU tune, Ark catback, JT intake, UP FMIC, E15, BMS brake snip
7. 11.921 @ 116.24, @GetStung 7.687 @ 93.26, 1.733
AWD, JB4 Map8, WMI, Secondary CAT bypass, Borla catback, Injen intake 93 octane + E85, E30, BMS brake snip
8. 11.946 @ 116.04 @C Mandy, 7.683 @91.08, 1.671
K&N typhoon intakes, JB4 ,Map8 WMI, 94 octane, mufflers removed, secondary cats hollowed out, interior removed (pass seat rear seats spare tire parcel shelf). and a hybrid version of the BMS burnout switch
9. 11.948 @ 118.11, @STINGER, 7.77 @ 92.99, 1.89
RWD, JB4 map 3, WMI, VT Snorkel, K&N Drop ins, High flow CAT, JunBL mid EVC cat back
10. 11.959 @ 117.80 @Kinvara8017, 7.75 @ 93.28, 1.838
GT2 AWD JB4, WMI, UP FMIC, throttle body, VT snorkel, BOV, Custom primary cat back straight pipe exhaust, brake mod
11. 12.022 @ 117.42, @Stinger33 7.82 @ 92.85, 1.94
RWD, JB4 map6, JT intake, JT exhaust, Throttle body, GFB BOV
12. 12.080 @ 115.37, @twn2rbo (Brian B.), 7.80 @ 90.75, 1.754
GT AWD, JB4, Injen intakes, SSR mid, Stillen Catback, BMS brake snip
13. 12.09 @ 114.83, Miguel P, 7.80 @ 91.61, 1.86
GT2 AWD, Tork ECU Stage 1, CX CAI, CX FMIC, muffler delete.
14. 12.13 @116.78, Jesse P turbokits.com, 7.89@ 91.51, 1.87
AWD, Lap3 pro mode 2 (old mode 3), Intake, FMIC, no cats, 93 octane.
15. 12.13 @116.16, @DaBears4Lyfe, 7.89 @ 91.61, 1.87
RWD, JB4 MAP 8, CX Racing Intakes, BMS WMI, Lap 3 Primary Downpipesw/ HFC, X Force Exhaust w/ EVC Closed, GFB BOV, VT Snorkel, Sixth OCC
Yeah the Tork 11.71 @120 unsnipped is super impressive. If he snips or does equivalent in the ECU and adds DRs he will beat the hybrid turbo car before adding WMI.Nice run without the snip! Looking forward to more and more people getting to the track.
That’s excellent news! I think a big gains can be made with trans shifting improvements.Yeah the Tork 11.71 @120 unsnipped is super impressive. If he snips or does equivalent in the ECU and adds DRs he will beat the hybrid turbo car before adding WMI.
Good news for me I should get a tune update soon. He dropped almost .3 from last season with just Tune changes. I'm running a tune from late 2018.
Yes 174 is terribly heat soaked. Most of the top times on the list were ~100 degrees IATs if I recall correctly.
Hey, do you have the slip for your new best run?Last night we had 3 Stingers at Pacific Raceways. Several head to head Stinger races. Tork caught some video.
I was 8 for 9 on the night including beating an M3, C6 ZO6, and 2 older drag cars, one a twin turbo v8. My last run of the night is when I spun tires and throttle cut I was facing a super charged RS4 who ran his best 11.801 to my 11.800. Would have been a epic final show down of the night but beast mode bit me. (Beast mode is the full throttle version of the brake snip. Usually I get a milder version)
Earlier in the night Tork and I where both sitting on 11.81 bests, but Tork blew out his last run and my last run blew up. Lol.
So I get that its pointless to run when I'm that hot, but I'm curious how others get around it. I was sitting in the staging line for probably 30 minutes while they cleaned the track so I turned my engine off. I realize now that I should have at least popped open my hood. I'm not new to cars, but I'm new to racing (and new to the stinger) so any pointers are appreciated.
Yep, we can't even put ice bags on our intake manifold since it's plastic. Nitrous spray on the intercooler maybe?Water/Meth injection is the simplest/safest/full-proofest method to get that job done. Any other method isn't going to accomplish what you are looking to get done.
Sorry, meant to post my and Johns slips last night along with the list update but it was late.Hey, do you have the slip for your new best run?
The non WMI guys are probably more like 120-135 degrees for their best runs. Above 135 or 140 my times drop off noticeably.Yes 174 is terribly heat soaked. Most of the top times on the list were ~100 degrees IATs if I recall correctly.
Popping the hood helps quite a bit, 10 degrees or more. Its also luck of the draw. If you get front of line and pop the hood and are the first or second one off after a wait you can have a fairly cool temp. But yeah nothing beats WMI or air to water intercooler.So I get that its pointless to run when I'm that hot, but I'm curious how others get around it. I was sitting in the staging line for probably 30 minutes while they cleaned the track so I turned my engine off. I realize now that I should have at least popped open my hood. I'm not new to cars, but I'm new to racing (and new to the stinger) so any pointers are appreciated.
A lot of the heat soak issue is a software issue more so than an actual heat issue. Warm intake temps result in timing pull even if on high octane like E85 mixtures, race gas, or WMI. The JB4's IAT spoof wire can be useful in situations like that to spoof IAT lower when you know the octane is there to support it.![]()
