Aftermarket Wheels
What is Your favorite Wheel?
  • Total voters
    235
I'm sorry to tell you guys, but it's not my car :ninja: I was looking for wheels again and found this posted direkt from Tomason.
but I agree with all of you, the car looks great. I'm thinking about buying those wheels once they get legale over here :rolleyes:
Oh, yeah (smh), BLACK in your signature (in bold no less). And I keep doing this: telling new members to put car details in their signature, and then I don't look and say stupid things like ^^^. :p
I don't think I have seen this setup posted. Does anyone know if 19 x 9.5 with a +35 255 35 all around would work? I know the back probably won't poke. But how much would the front? Would it even fit on the front? The ARKs are 19 x 9.5 +25. But those poke a bit too much for my taste.
I’m not sure if anyone is running 9.5 up front, +35 is in the ball park but 255 is the max of what I’ve heard. So you’re probably ok, or close to it, if it ends up being tight on the front end, you can probably work with a 5mm spacer if necessary.
Rears should be ok. But 9.5 IMO may just be too much wheel up front. You'd have to be exact with the offset. Too low and you will either poke or rub and too high, you run into clearance issues with the strut. I can't say with certainty that it won't work but if it does you have a pretty narrow range of offsets that may avoid both those issues.
Going with these as winter wheels.......maybe summer. Wrong car though. Liquid metal instinct 18x8 40offset. $96 each as long as they last at discount tire. 23lbs.
Quoting old post, I know, but that's literally my old car!!
I posted that on Acurazine when I owned that car!!
Verde V99 Axis Matte Graphite
F: 19X8.5 32mm offset
R: 19X9.5 38mm offset
Installed today. They used bands to secure the sensors, then used short valve stems that I'd ordered on Amazon.
When I was at the tire shop, there was a white Stinger in for new tires at the same time.
Well, that counts as a "wild Stinger sighting". :D
I've looked through the pages and can't find anyone on a 20" x 10.5 et 40 lowered. Any help?
There are people running 10.5+45 and are pretty flush with no rubbing, 40 might poke by <=1/4 inch i would assume it should work. Report back! ;)
Worth noting that the standard size tire for 20x10.5 is 285r30 which is a little less than an inch taller than stock, so you have some wiggle room there if you want to try a smaller overall diameter with a 275
Yea I was thinking 275 as well. Just wanted to see the set up before I pulled the trigger. I'll keep searching the boards.
Stance SF07 19x8.5 +35 w/245/35/19 Pilot Sport 4s front & 19x9.5 +40 w/275/30/19s with stock springs:
@Kazz o you plan on running this as your winter setup too? Or, are you going to RTS for winter?
I purchased mine in December of 2017 and it came with the 18" wheels with all-season tires. Those are my winter setup. When the all-seasons are toast I'll be purchasing dedicated snow tires. We get to 20+ below zero Fahrenheit in the winter - and I've driven this car in about 25 below, actually.
I get it, I'm in Michigan...:thumbdown: I got my car in February and rolled the rest of winter on the stock 19's. Far better than I thought it would be!
The all-seasons did really well. I think it's about the weight and AWD.
