Revvdmedia
1000 Posts Club!
I suggest getting a baseline Map 0 log before you go onto the maps so at least you have a starting point. Get a good third or fourth gear long pull from about 3000 up or so, and log some 0-60's if you want. I did not do baseline logs and now I need to do some to see if my car is slow or performing as it should. I'm at 2200ft and I have yet to beat a 5.15s 0-60 with launch control per JB4 indicated times (I know, inaccurate), or a 13.19 @ 107mph with Map 2. Those are stock AWD times (probably at sea level). I expected high 12's at my altitude. Maybe my car is just slow to begin with. The only thing I've seen in my logs compared to numerous others I have looked at is my timing overall feels lower than the "better running" cars. Terry does not note octane issues since I am not getting timing pulls from individual cylinders, but I still think my overall timing could be stronger. I just pulled my best street launch at JB4 indicated 5.25s this week when I went down from Map 2 to Map 6 pulling a flat +4 boost.
