Try it and look at the logs or post them.Sorry to revive this, but would I be okay to run my jb4 + regapped denso plugs + fuel wires with 91 pump on map2 consistently?
I've been running on map1 all the time, but im curious if I can just run map2 all the time.
I would agree with that, if 91 was 91 all over the country / continent. Canadian 91 is probably like "good" US 89 or even 88. CA91 is probably in a similar boat. GOOD US 91 probably works just fine..
There's posts on it, even on Top Tier Shell/Esso 91 people are getting different results than on US 91 gasses.Can you verify your claim why Canadian 91 is US 88/89?
Thanks!
And then there's our Petro Canada 94 which is like good Shell 91 which is like good US 89, so we basically just fill our cars with water and sand.
With that being said is it worth damaging your engine if there is even a POSSIBILITY it could do damage?
Also note that the difference between Map 1 and Map 2 is only 14HP and about 27 lb-ft in the bottom end between 2250-5250.
Also on the note of 91 Canadian being more like 88/89 US, the 91 rating is how much it resists knocking so while it may not preform as well power wise it should technically be as resistant to knock.
I don't think octane works like you think it works. If Canadian 91 is more like US 88/89, then it means cars on Canadian 91 usually perform like US 89. Higher octane fuels have LESS energy, but better knock resistance. That's the only performance difference - knock resistance. So Canadian 91 actually is NOT as resistant to knock as US 91.
I don't know what the difference is, in chemical terms - perhaps octane ratings are not as strict or as strictly checked in Canada. Or, in the US they "underrate" their octane. I used to feel all smug driving on Sunoco 94 in the K-W area for years, thinking I had better gas than most people in the US, only to find out that wasn't really the case.
Lots of speculation blowing around about 'inferior' premium gasoline in Canada - and I've yet to see any empirical evidence to support that.
Canadian gasoline has strict requirements for quality and content including the advertised octane rating, fuel is regularly tested, and I seriously doubt that the refineries have been pulling a fast one on anyone ...
I'm just going by @Terry@BMS 's posts, people running 91 in Canada aren't seeing the same results as people running 91 in the states. I'll look around and see if I can find the posts with logs.
