okay. cool.I have 2019 AWD with 19" wheels.
Yes, I know they are available, but they seem to be difficult to find.I have 2019 AWD with 19" wheels.
Or lucky. I went in, they traded for the color my wife wanted and the three "must have" features that I wanted (3.3L, Harman Kardon and sunroof), and by that afternoon I was driving around in my brand new car.Might be. I was looking for 2019 GT2 AWD in white with red interior and 19 inch wheels. No dealer had one in the area, so a dealer traded one from VA and got me one. After a week another dealer in my area got the exact same specs. You will need to be patient when you are looking for specific specs.
I didn't even know about the 18" and 19" wheels issue (lower top speed vs the 167 MPH vaunted top speed). So it never came up. And I got lucky again.Had I ended up with 18" wheels and the 130 MPH limited top speed, I'd have been seriously annoyed; and long before now I'd have attended to that by getting somebody to raise the limiter to at least the Kia specified 167 MPH. Probably I'd also have gone to wider aftermarket rims (as I have done now) but kept the setup squared. I don't mind staggered, but squared seems to make more sense for anyone not tracking their car. I doubt that anyone of my driving level would ever notice any difference in handling between the two. And rotating tires is a good thing (full treadlife warranty).
What is the appeal? I don't see enough sidewall difference to create a fuss. If the 167 MPH is not a deal breaker, what is the attraction for 19"? If it's higher aspect ratio (rubber band tires, heh), then why not ditch both OE rims and go 20" aftermarket and have done with it?I didn't care much about top speed but I really wanted staggered setup.
The price is half the treadlife. I'm still conflicted about this.Now the appeal is slightly better grip.
The price is half the treadlife. I'm still conflicted about this.![]()
The main reason I want the 19 inch wheels is because they are 255 width in the rear, I have seen stingers on the road with the 18 inch wheels that have 225 width tires in the rear and it looks horrible, not much wider than a bike tire. I won't be driving anywhere close to the 167 MPH top speed and probably not even close to the 130 MPH top speed since I don't plan on tracking the car either. The only reason I want the 19's in for the wider tire in the rear.What is the appeal? I don't see enough sidewall difference to create a fuss. If the 167 MPH is not a deal breaker, what is the attraction for 19"? If it's higher aspect ratio (rubber band tires, heh), then why not ditch both OE rims and go 20" aftermarket and have done with it?
since the 19's are high performance tires, you will need to get winter tires once the weather gets cold so you are technically splitting the miles on 2 sets of tires which should make them last even longerSo I just checked my last last oil changes at 6000 miles inspection report. It shows 8/32" on all 4 wheels. So AWD did a good job I assume. But I would end up changing tires at 24,000 miles (assuming I started at 10/32", so 2/32" per 6000 miles).
Lol! Really, now.I have seen stingers on the road with the 18 inch wheels that have 225 width tires in the rear and it looks horrible, not much wider than a bike tire.
But it's only half an inch difference! Do you really see that? Many on the forum have opined that the OEM Michelins look too narrow; so they actively go for as wide as they can, even using spacers to add clearance because of offset issues. My Nitto Motivo UHP A/S are c. 9 wide in front and c. 10.25 wide in the back. They look wider of course than the Michelins, being an inch wider in front and almost 2" wider in the back. The Michelins are currently on the TSW "Watkins" rims which are half an inch wider in front and one inch wider in the rear than the 19" OE rims; so the Michelins look a little bit stretched, but also provide very stiff cornering, very planted. I'm wondering if the Motivos would work better on the wider rims too. They would look really good on the wider rims; better than they do on the 19" OE rims (which I use for my winter driving). So when my Michelins are shot (the rears are getting close), I don't know what to get: I was thinking Pilot Sport like I have now. But do I want to keep replacing them every c. 15K miles (or less!)?The only reason I want the 19's in for the wider tire in the rear.
It seems like more than a half inch difference, but regardless it is definitely noticeable to me.Lol! Really, now.
Rear contact patch on 19's are wider, fronts are actually narrower.
225/45R18
Tread Width: 7.8"
225/40ZR19 (F)
Tread Width: 7.6"
255/35ZR19 (R)
Tread Width: 9.5"
Yes exactly, i knew it was more then that.Even just going by official specs: 255 - 225 = 30mm = 1.18 inch. So it's really hard to call it "half an inch".
since the 19's are high performance tires, you will need to get winter tires ... 2 sets of tires which should make them last even longer
Nitto NT555 G2 = 320 UTGQBridgestone Potenza RE97AS-02 = 400 UTQG
Michelin Pilot Sport 4S = 300 UTQG
