Does this work in conjunction with the factory remote start, as a way to give better control over it or as a stand alone remote start?
And are their options to disable unwanted features (reverse hazzards)?
@K8 Stinger Store
I would get it for 1 feature: the remote start that doesn't require a restart of the engine when you get in nor a second FOB. I would actually NOT want the car to unlock itself when I got close nor would I want the hazards to come on every time I put the car in reverse. If I could disable and enable features whenever I wanted then maybe. After I get an IC, Eibach pro+ kit, frame collars, wheels, and paint protector, if there is any money left after dropping 10k on other mods, then maybe. Ask me in 5 years.
Yes lower price than factory remote start. Now examine the install and wiring diagram, very complex install and probably expensive labor to install.
Does this have takeover? I didn't see that mentioned when I read through it.I'm down. Was going to get the factory remote start but hated that it didn't have a takeover option. Was looking through the install instructions and while yes its pretty involved, I don't see why you couldn't use the positaps like on the JB4 fuel wires for most of the connections. There are a couple that you actually have to cut and place relays/resistors inline but most are just tap connections.
Chad
Has anyone read through all the instructions?
The Wiring Diagram and the Test and Setup files don’t seem to match. The wiring diagram has 15 wires plus a relay and some other relay type thing. However the Test and Setup file only says to connect 8 wires. All this is excluding the sunroof wires.
Am I just reading this wrong?
It’s obvious the instructions are adapted from another set but don’t slap K8STINGER on the page if it’s not for the Stinger.
This has just been released on the K8 Store for $299.95. Has anyone installed this? I'm curious how difficult it is to install as the instructions seem vague.
