StungBlueGT2
Sustaining Member
Agreed, the biggest 20wtq gains are in a narrow RPM range but looks like a minimum of 5whp from the beginning of the results. Most likely a 5-20wtq gain throughout the entire max torque range(1300-4500rpm). So unless you’re at WOT all the time that gain would be in the most usable range, especially for daily driving.Yes there are 10-20 Tq gains at fairly narrow low RPM. I wouldn't say this is the most usable range. You are trying to apply a WOT Tq gain to partial throttle applications in daily driving which you can't do. You could argue a suspected MPG/ efficiency increase I guess. If you go WOT the car will shift and you never use this 2800-3800 RPM range. This car already has tons of power for daily driving and if I need more I push the pedal harder. Dynos are full throttle and performance measures are full throttle so that's what I'm focusing on. I just don't think a partial throttle gain is a real thing as who knows the difference between 40% throttle and 45% throttle. If you do go full throttle short shifting, which isn't a great idea for knock and stress/loads, then you do have a point it is a good mod.
Also, power gains aren’t specific to WOT only. If the engine is simply more efficient at making power then that effect will be true at all times, not just at WOT. Actually, there may be even more noticeable gains at partial throttle since the engine doesn’t need to work as hard for equal acceleration. Unfortunately nobody does half throttle dyno runs so we will never know for sure but I bet the gains at part throttle would be the same if not greater than WOT. The few Stingers I know that have 2ndDPs sure feel quicker off the line at any throttle input not only while flooring it.
As I said before if the only focus is WOT gains near redline then the 5-20wtq gains from 1300-4500RPM doesn’t matter much, but most people would enjoy that extra power the other 95% of the time.
Very true but if catbacks will produce 10-15HP by removing exhaust restrictions of the mufflers, then it only makes sense that removing a bigger restriction(cats) will produce the same if not better gains throughout the whole rpm range.On a brighter note, the catbacks seem to be about 10-15 HP so you get to sound cool and go a little faster too.
My ark grip was 10 HP. 2 before dynos from different stingers on the same dyno hit 243, mine hit 253. So assuming my car was average.
Guess will will have to wait until more dynos are provided, but so far 20wtq from mrsmoofy and 20whp from mistermac means there are good gains to be had from 2ndDPs one way or the other.
