Driver
Interesting - the Aussie stinger does not have that Wi-Fi icon; nor UVO; or even that HD radio & Sirrus decals on the dash.
I did but have decided to stay away from messing around with it. Thanks anyway@AV8R did you see my previous post? - #45 - The access steps have changed, however I now don't know what the correct pin code is.
Hi mate did u figured out pin code by any chance?Since the latest SatNav update; the original screen-saver method no longer works.
However the new process seems to be:
1) Go to Settings > Version
2) Tap 4 times on the Map text THEN tap the actual map version number. (Sequence also works against the firmware text & version number)
3) The PIN prompt then appears and now I now have no idea what it is.
1111 as seen on other Kia/Hyundai forums doesn't work (which tipped me off to this process)
0000, 1234, time in 12 & 24hr, date ddmm, mmdd, mmyy, same with the update date in similar fashion are all no go.
Welcome to our stingerforum, which colour Stinger do you own, and where do you live in Australia ?Hi mate did u figured out pin code by any chance?
NopeHi mate did u figured out pin code by any chance?
I saw a video on YouTube and the code is the time it show on the car!Nope![]()
Did you try entering “IDKFA”?Thanks but could not get 2400 to work on Stinger.
Did you side load some apps?
thank you will try it tomorrow and report backI'm in
The new code is 2998
As per my post above; access via the settings > about menu. Click the "map" text 4 times; then click the map version number text.
The bad news is there's less options & no Android menu compared to last year's firmware.
