I should’ve asked this before, but how and why are the bolts modified?Intro pricing was $172
Bolts are modified OEM bolts that cost $35 each at KIA.
If you want to home depot your Stinger though. Have at it haha
Also, your website says
There is nothing on your website saying they are modified OEM bolts.
- 4 Custom Machined OEM Grade 10 Subframe Bolts
The description says OEM grade not that they are modified OEM bolts. If they were modified OEM bolts it would be superfluous to say the OEM bolts are OEM grade. Understand??!?!?!? "Custom machined" == modified, OEM == OEM.................
Thank you for this feedback on the product.So I finally got my car back and have put on about 100 miles with the subframe collars/bolts. Is it worth $200? To me, yes. I am glad I did the modification. My only suspension mod is eibach springs. The car now rides even a little smoother than it did before. There seems to be less bangs/thuds over bumps. I also do feel less body roll than before. I think the video is a little over the top but I am very happy with this setup.
There was one highway joint on a curve that always made the Stinger feel like I was going to sideways hop into the next lane even in sport mode. Today I was in comfort, and I hit the joint much faster than I normall would to test the wheel sideways hop. None! I have experienced zero sideways shimmy with these and the Eibach springs. The Eibach springs did reduce the shimmy but they were still there.
I LOVE my setup. It’s much smoother than stock over road imperfections and handles much better. This is how the car should’ve come from the factory. Will a sway bar help handling more than this? That I can’t answer but I’d assume it probably can. But with these you give up no ride quality and you actually improve it a bit. I am perfectly content and have no plans to further modify the suspension.
That doesn’t make much sense to me. The collars keep the car from flexing as much which reduces rattles and creeks. My sunroof was crazy loud creeking and seems to have been less noisy after I had the collars installed.Ok, update after almost a couple of weeks. Started developing sunroof and driver door creeking noise, on the good side it means the collars are doing the job, on the bad side it means its creeking now. I presume that without the collars there wasn't as much chassis flex.
Gotcha. Interesting you are experiencing that. It’s definitely the opposite for me.Actually its the other way round.
Previously, when any movement is happening in the front and rear axles the gape in the collars will allow some movement to avoid unecessary stress on the chassis. Now with the collars in place there is no give for that, so any movement even if small will immediately load it on the chassis.
Purchased these from @K8 Stinger Store and received them today. What have other people done about this problem? The tabs on the plate do not seem to be addressed in the instructions.Installed the collars yesterday, pretty straight forward. Quality is very good, fitment perfect, the installation video helped a lot to quickly identify the bolt location. All in all, two guys working at a moderate pace with a lift, took 1:45min.
My only comment is the rear/rear collars, there is a plate that you need to remove (minute 11:35 installation video), the plate has two tabs, once you fit the collars there is no place for the tabs to fit in, so you basically have to ram the plate with the gun/torque wrench. The problem is the tabs will damage the collar and they will also bend inwards and if they bend inwards enough they will damage the bolt, you will also be left with a gap between the plate and the collar as there is no way to fully bend the tab inwards and flatten them because they will hit the bolt, the tabs really should be trimmed, maybe leaving 1mm or so of the tab just so that it doesn't turn after its installed.
The instructions seem to indicate that you just drive the plate with the tabs into the newly installed collar and something will bend somehow with your "two ugga duggas" from the impact wrench. Does not seem right to me.
On @STINGER suggests to cut them as have some others on FB, Some on FB mentioned drilling out some clearance holes for the tabs to fit into. Anyone else have any ideas? Am I doing this wrong or overthinking it?
OK Ladies and Gents!
DO NOT MODIFY THE DAMN PLATE!
DO NOT REMOVE THE PLATE
INSERT YOUR COLLARS AND USE THE BOLT OR NUT DEPENDING ON WHICH HOLE YOU'RE WORKING ON AND DRIVE THE COLLAR INTO THE HOLE!
I'm not even sure why Hyundai and Kia both added those stupid ears to them. They are pointless and don't do anything.
IF your collars are tough to get in past the ears. Use a punch and a hammer and knock them into the slots a bit more so they aren't in the way. Then insert your collars, and tighten your nut or bolt again depending on the hole.
I'm not sure why people are over complicating a level 1 installation with wild guesses of how things should be or shouldn't be.
The plate, cannot turn and loosen your bolts or nuts. Period! Under any circumstances! Those ears are just a new pointless thing that a lot of the newer kdm cars have.
Also:
Collars cannot cause any rattles or weird noises. Especially with sunroofs.
If you use the search option on Google or on this forum. You will know that the Stinger has issues with rattling sunroofs. The repair is to remove the headliner and loctite the bolts/nuts whichever is holding the sunroof in place and it will go away. It rattles because they get loose from poor assembly standards. You can either fix this yourself or take it to your dealer and ask them to do the fix.
