Kato_the_kia_stinger
1000 Posts Club!
- May 22, 2018
Not bad times at all though. 11s will come.
I do and I'll send it to Terry. This has happened in the past at the same mph. We couldn't solve it so he suggested that I paddle shift the last gear just before 114. That works but I havent had the issue in a while really thought meth would put an end to it as I suspected it was an octane thing. 2nd run I paddled at about 112. Ran a 3rd run with the car seeming to slip a bit and squirmed out of the hole. 12.14@116.77.Did you have the full log of the run where it cut? Any idea what happened or why? I saw the snippet you shared above showing the boost drop for a few cells
Thanks!Looks like the WMI is able to overcome most of the heat soak issues as your track times are similar to your warmer weather dragy runs.
How much weight reduction?
Nice runs, very close.
I'd kill for that 60, great run.First run ok for 65 degrees. 60 foot a bit off.
