Thank you for pointing out that the filter and OEM air inlets are about 5" apart, which is what I was trying to clarify.
It will naturally draw more hot air when compared to any intake with the filters facing towards and directly in front of the OEM air inlets(
Injen, JT, DIY versions, etc). The
Injen/JT are the best examples of the most efficient intake designs to draw cool air from the OEM air inlets.
Unfortunately the
Injen is missing the heat shielding completely, and the JT's backside near the turbos is wide open so they will both still draw hot air from the engine/turbos. They probably get more cool air from the front, but their advantages wont be significant over the BMS because they all draw in some hot engine air.
If any of these intakes simply added a full barrier of heat shielding between the filters & engine it would make a huge difference. That way the hot engine air would be kept completely separate, and all the air following the path of least resistance would be forced to be drawn from the front of the car.
I will see if I can find some or try to take some temps myself, but don’t have anything on record yet. However, I felt a huge difference with my DIY intakes. When I first added them I didn’t have any heat shielding and would quickly develop heat soak. The engine felt lethargic and the metal on the filters would be extremely hot even after a short drive.
Then I added a wall of thermal heat shielding and made a soft box barrier between the engine and filters. It made a huge difference and eliminated most, if not all of my heat soak issues. Even after multiple hard runs I still won’t get the lethargic feeling and the metal on the filters stay cool to the touch. Now there’s easily a 50 degree difference on each side of the shielding and couldn’t be more impressed.
