We are all forever in your debt for resolving such a complicated issue in one forum post. Thank you!Glad you finally caught on!
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
No, really, I am super duper serious. You nailed it. You are the brake whisperer.Plus, I accomplished it in less words than your single post which was full of assumptions, yet otherwise impressive quantities of verbiage. You should appreciate having actual facts from someone who has been through the entire process with the actual products.
If you had been correct, the original issues would have continued with the replacement rotors. I drive through mountains daily and use my brakes mercilessly. Though, I imagine your overwhelming opinion of self will never accept that you were wrong, either in part or in whole. It is good for our readers to be exposed to all possibilities.
I hate to feed trolls, but it happened to me after rotor replacement. Sorry to burst your enlightened bubble.Plus, I accomplished it in less words than your single post which was full of assumptions, yet otherwise impressive quantities of verbiage. You should appreciate having actual facts from someone who has been through the entire process with the actual products.
Thanks for the information provided, so I assume there has been a revision to the part number on the discs ? My cars booked in 2 weeks for a review of the brakes along with the 10K kilometre service.
Its good to have the correct information before going in
Cheers
What I don't understand is why someone without the problem would even read this post, let alone offer up "factual" advice on something they never experienced or dealt with themselves.
To those who are having brake problems, do not let @MisterMac 's comments sway you one way or the other. Considering that not all Stinger owners are having, or have had, brake problems, by his logic, the problem was "solved" from the giddy-up. I have no idea why a single person would consider their singular experience with the brake issue the basis for solving all of the brake issues mentioned to date. Why not just say that you changed rotors and not pads and that the problem has not reappeared? Simple enough right?
As stated many times before, whether YOU suffer from it or not, the brake pads depositing onto the rotor surface unevenly is a well documented issue by multiple Stinger owners. The brake pads are the problem. It may be one lot of one production run, 12 lots of 3 production runs, etc. but some brake pads are bad. It is documented in at least two Stinger reviews by automotive journalists and Kia's own on-site techs solved the problem by using a different compound of brake pad, not swapping the rotors.
Lastly, your position sounds so much better if you can substantiate your claim with new rotor part numbers, a Kia tech bulletin, or something more substantive than you single personal experience. Instead you make bold claims and then ask others to look up part numbers and refute your claim. And for the record, being the first (or one of) to experience and identify the pad deposit issue doesn't make you the authority on the brake issue anymore than being the first person to eat Chateaubriand makes you Anthony Bourdain.
By the way, I am glad that you do not have the rotor problem anymore. I hope that everyone else has a similar experience once their "fixes" are put into place.
No worries @MisterMac . Thanks for posting this. I think we all want the best for Stinger owners, there is no doubt about that. Please continue to let us know if your brakes remain problem free. I am on new pads and rotors and so far so good after 4k miles.@Helo58, this is well written and my apologies for poor communication. One size does not fit all. I simply want those who may have limited funds to have hope of getting their rotor issues corrected for free by the manufacturer. In reading this post, and mine, I now see that I what I had hoped to communicate was not achieved. That is on me.
The reason I am suggesting to check the part numbers on your front rotors is that the Brembo (j5500) and non-bembo (j5000) are similar. When my rotors were replaced, the tech said the part numbers on the originals were not clear. He said it was possible the non-brembo rotors were installed on my car during the manufacturing process. Kia corporate had the shop send the rotors off somewhere (Lala land?) to be checked. I would hope that if the non-brembo rotors were installed, and it is tied to a particular range of VIN numbers, Kia would issue a TSB. The dealership has not had further contact from corporate on this.
I was not able to verify the original part numbers with my own eyes and for 10,000 miles I have refrained from saying anything on this rotor issue. My immense hope was that the replacements would also fail and I'd have justification for upgrading my pads and rotors. However, after having no further issues, I am inclined to believe his assumption was correct. The rotors without issues are clearly j5500.
Of course, this is the same tech who was unable to figure out the issue with my XM radio for a week, even though I provided a video of this lack of sound. Then, when he replaced the head-unit and amplifier, he forgot to transfer my NAV disc from the old head unit. It took another five days to have it shipped back to us for install.
I suppose if enough of us with early 2018 models with Brembo Brakes check their part numbers and find j5000's installed on the front, we will know if that is the actual problem.
For what it's worth my car is a Nov17 build and I had my rotors machined around 3k miles ago. When I got the car back I swapped out the stock pads for Girodisc and the properly bedded them. Mileage on the new pads is still low but the issue hasn't reoccured, yet.
Same here. But I brake like a grandpa (I am a grandpa), which is why mine at over 16,500 miles are almost like new.My build date is 02/18.
Ditto. 12,000km. Kia said at the 10,000km service there was very little wear. I tend to look into the distance and take my foot off the accelerator when approaching lights or stop signs.Same here. But I brake like a grandpa (I am a grandpa), which is why mine at over 16,500 miles are almost like new.
@Helo58, ...I now see that I what I had hoped to communicate was not achieved. That is on me.
I had a Lexus ISF with Borla catbacks and the biggest thing I miss is the V8 sound. The brakes were great too but very dusty and corrosive due to the metallic pads. I had to repaint the calipers and wheels as a result. Definitely glad the Stinger has ceramic pads.Well, @BabblingBafoon. ... and the sweet sound of a real V8 with a CORSA exhaust. Thanks!![]()
Because I'd still like to be able to do these things, I would like to upgrade my brakes (rotors/pads... maybe even pistons for 6 pots) to something that can take that abuse better and not give me the pucker moments. I realize I *could* change the way I drive/brake and never experience these issues, but I don't want to do that and I am willing to spend the money to replace components knowing the car wasn't originally designed for this... which is why I am looking for great alternatives and seeking that advice.
The one off-putting thing about all this brakes and pads upgrade talk for me is the related dust, the corrosive environment around (especially) the front wheels and rotors. I want to know that my car has the potential to let me be a "hooligan" (even if I never am), i.e. tires, brakes and suspension mods all make her track worthy: and yet I want to avoid the brake dust.Well, @BabblingBafoon. You've hit on one of two things I dearly miss about my SRT Charger: Those aggressive Brembo brakes that never missed a grip (drilled & slotted rotors plus super dusty pads) and the sweet sound of a real V8 with a CORSA exhaust. Thanks!![]()
