Drag/Acceleration Kia Stinger 1/4 Mile Times
Status
Not open for further replies.
Below is the number 4 and number 5 spot on the track 1/4 mile
Seems like the Tork ecu stage 1 tune out performs the JB4 on map 8 at least on the Track with similar mods.
There both AWD. The only diffference between the 2 is Kato is running WMI and Miguel is running an Intercooler, which they somewhat offset each other. I believe the WMI is more effective than the intercooler but that is just my opinion.
I think the JB4 on map 8 runs more boost than Tork stage 1.
Tork 17-18 psi on stage 1
JB4 probably runs about 7-9 psi over stock on map 8, JB4 probably runs anywhere between 18-22 psi. Than means the JB4 is running about 2-4 more psi than the tork Stage 1 tune.
Someone correct me if I am wrong but based on this info this is what it seems.
4. 12.09 @ 114.83, Miguel P, 7.80 @ 91.61, 1.86
GT2 AWD, Tork ECU Stage 1, CX CAI, CX FMIC, muffler delete.
5. 12.12 @ 116.82, @Kato_the_kia_stinger 7.91 @92.12, 1.92
AWD, JB4 map8, K&N intake, VT snorkel, WMI, 93 octane
Meanwhile, I'm running 12.1-12.0 with 18.5psi peak boost with just Dp's and intake.
I'm all about more with less!
With map 8 there's not a set boost level, you set it yourself in the app. He could be running 15psi, he could be running 18psi. It all depends on the boost additive setting. Also if you think a 12.09 @ 114.83 is "outperforming" a 12.12 @ 116.82 (2MPH faster) then you have a lot to learn about drag racing. That's not a small difference
Yeah, whatever helps you sleep at night:)
I ran a 12.17@116 at the track so yeah, I know.
So funny, everyone always trying to be a professor of racing here.
Ok boss! Thank you sir you really seem to know a lot about drag racing....... Oh wow I just noticed you came out of your hiding spot lol.
Just curious what are all your mods? Awd or Rwd? Stock tires ? Can you provide me a bit more info please.
Dec 22, 2019
Full weight+ carseat and spare
GT2 AWD
Oem rear tires aired down to 30psi
E30 (5gl e85,10.9gl CA91)
My 205lbs self
56* pretty decent DA's.
Injen intake
Lap3 Catless primary Dps
Dec 22, 2019
GT2 AWD
My 205lbs self
Injen intake
That’s pretty impressive!
Wow lol I took off both of car seats and the spare and still got a slower time. I also weight a little less than you at 175lbs.
I don’t have primary downpipes. Do you have secondary downpipes as well like the ssr? Any issues with the primary DP, boost issues? I heard of some people having overboost issues.
Another question are you running a JB4? What map?
Another dumb question, did you noticed that lowering the tire psi helped your run? When I did my run I had like 38 psi lol.
My bad, yes, Lap3 Protuner mode 2.
Catless primary yes, no . 0 over boost issues.
Nice to see someone with a Lap 3 pro. How do you like it ? I ask because I know a couple people who have JB4 and primary and had overboost issues.
No mid pipes? Then we should edit your slot on the list. I think it says you have mid pipes. Also, Who is overboosting?
I know a couple people that had issues with JB4 with primary DP. They had some overboostong issues.
I know Lap 3 sell the primary so I figured there Lap 3 pro would not have any issues with overboosting. I wonder what the difference is between the JB4 and lap 3 pro? I have not heard of anyone with a lap 3 pro and primary DP complain of overboost issues yet.
That's good to know. I have to look at that before I make my decision on pipes and exhaust mods. Come to think of it, I don’t know anyone with a jb4 and primary cat delete. Only mids.
Kato, my current set-up is what I listed .I did reinstall the oem midpipes after having some oil burning issues due to insufficient back pressure on turbo seals .
My 1/4 miles we're achieved with Ssr
midpipes,yes.
Angel, I've posted quite a few videos via fbook and on my YouTube channel. I've been using lap3 since about 2015 with my FBO sonata. After using several other KDM tuners (sfr,BTR,etc) this was a totally diff experience. Silky smooth throttle mapping etc.. so when I got the Stinger, my mind was already made up.
I couldn't be more impressed. Call me whatever you want, shit is legit .
And no, 0 issues. I have never experienced anything like the others. I have had fuel cut due to lack of octane which the ProTuner is super sensitive to. It was resolved by simply splashing more E and driving for 10 min, then it was all gravy.
PM @DaBears4Lyfe for life he can provide some info on that matter.
I have another guy local to me but he is not on the forum.
This is something that you should do more research and get more info prior to getting them.
I personally was going to get them before I seen a couple people have issues with them. I personally don’t want to spend the money to buy a lap 3 pro just for primary DP. I will patiently wait for BTR to come out with there ecu tune.
One more thing worth mentioning. If you get primary DP don’t get the NGT, pay $100 extra and get the lap 3. I heard a couple have fitment issues with the NGT and it cost them a lot more than $100 bucks to fix.
I’m definitely deep into the research. I don’t think I’ll end up with DPs or removing the primary cats. That’s a bit too aggressive for my interest. But the mids and back, I’m considering some options. Thanks for the input.
midpipes,yes.
Good to know it’s legit! A lot of the times you get reviews for the lap 3 pro from people that don’t own the lap 3 pro and that can be deceiving/biased.
Just to be clear you only primary downpipes, no secondary and the oil burning were caused when you were running full catless?
Status
