Sorry for the delay in getting this written up.
This weekend I installed the snorkels which was fairly easy even with trying to save as much of the shroud as possible. The hardest part was removing the clips for the wireing harness as there isn’t much room to get a tool in there to pry them out but that took no more than 5 min.
I taped everything up when removing the bumper to try and keep from having any paint issues.
After getting the bumper off I found some interesting things stuck to my intercooler including this butt and a dragonfly.
Here you can see the stock snorkle and how it comes up from behind the radiator shroud. This is when I realized that saving and of the upper scoops wasn’t going to happen. However there are still guides for the lower half of the radiator that I wanted to save.
With the shroud out this is where I cut it to retain the lower parts. This keeps two of the bolts per side so it’s still firmly attached. It also keeps all the mounting holes for the wireing harness that runs across the front.
To cut the shroud I used a combo of snips and a Dremel. The plastic is fairly brittle so the snips would cause the plastic to crack a bit further than where it was cut. This can’t be seen when the bumper is on so no need to make it look pretty.
Here you can see the snorkels installed with the lower shroud
Close up of the shroud and the snorkels.
Bumper reattached
I wanted to do some testing of air temps before and after install. Unfortunately I started baseline testing on Saturday where it was about 85 degrees and by the time I got the readings it had dropped to 78. And Sunday after the snorkels were installed it was in the lower 90s.
To do the testing I hooked up my FireBoard that I use for smoking with 3 ambient temperature probes. One in the duct, one in the K&N air box behind the filter and one on the other side of the air box in the engine bay.
Here is a view of the probe in the duct from the front of the car with the snorkel off.
Here is a read out of the temperatures over a 20 min drive. As you can see the car started out at about 125-130 degrees. As soon as the car started moving at about 45mph the duct and filter temps drop below 100 degrees.
Each of the spikes is where I stopped for a light or traffic. All three temps would increase but as soon as the car started moving the duct and filter temps would immediately drop while the engine bay would slowly drop. Cruising at about 55mph the duct and filter temps got very close to ambient temp.
Also for those that thought the K&N mistakes didn’t do enough to block engine heat, you can see the filter is seeing ~30 degree cooler temps than the engine bay. The two probes were about 2” apart with just the K&N heat shield between them.
In addition to seeing he temperature changes just looking at the design installed you can see how there will be much more air traveling through the snorkel and over the filter which will help overcome heat soak.
Also I drove though a bit of a rain shower on the way home yesterday and the air box was dry. There was still water on the hood and grill as well as a few drops on the mouth of the snorkel but none in the air box.
