Metalmania82
Definitely diggin these. Looks like it should help funnel some more fresh air and help with the JB4 tune.
Hi Dan, have a concern of water ingress together with the full frontal ram air. Am from tropical Singapore and we get big downpours quite often. Have you tested for this?
No, but you did miss the part where I said I’ll be installing them this weekend.
Yes they emailed me an install manual. I read over it and don’t remember having to tap any holes, should utilize existing hardware.
They do say to remove the radiator shroud and leave it off to avoid cutting or fabrication but I’m going to try and get both to work together.
You can keep the radiator shroud but only if you cut two large holes in them.
I would go that route too. Using two large drilled holes and connecting the holes with a hand saw is easy.View attachment 13313
Removing the stock snorkle and making hole even without the big mouth snorkle should help.
You would get a bit of a ram effect with the big mouth and less turbulent airflow. Theoretically.So what added benefit (other than looks) would this Big Mouth snorkel add over and above the cutting of holes in the factory shroud? Wouldn't the shape of the factory shroud help funnel the air into the intake in basically the same way?
Correct, and good question! Cutting a hole in the shroud will allow unguided dynamic pressure to build up which will help 'some'. Having a duct capture all the momentum of the air and physically delivering it to the airbox/filter is the proper way to create the ram effect. In layman terms, you dont want the engine to have to fight for air, you want to deliver it on a silver platter (low pressure drop).
Hello!Are the turbos ingesting any additional air versus the stock air guides? Seems like maybe a pressure difference at the turbo inlet would be interesting; any measurements there before and after smoothing the pathway with the snorkels?
Also would be interesting to know if the pressure changes behind the grille when installing the snorkels; if it drops, would that mean that the snorkels are capable of guiding more air than the aerodynamics of the car can supply?
Hello!
One can't attain more dynamic pressure than is present as dictated by Bernoulli's principle. But, what we do with that pressure is the magic of a well designed flow path.
Pressure difference at the turbo dictates at what RPM the turbo attains a target mass flow rate. Or, at a particular mass flow rate (constant turbine RPM) there can only be one pressure ratio. With that said, increasing the inlet pressure to an undersized centrifugal compressor commonly found on cars today such as the Stinger, decreases turbine RPM for a load targeted tune or increases mass flow rate for a boost targeted tune.
Either way, you'll see some nice benefits to having an efficient front facing ram scoop. Your tune will dictate how it shows up, the engine nannies and types of tunes will 'feel' that the ambient pressure increased by a small amount and think the car is below sea level, or at a negative DA, for example.
Best,
D
Interesting stuff, appreciate the info. What I'm wondering is, under what conditions are the snorkels removing a constraint to deliver this benefit? If the factory pieces are not flowing the available maximum from the area behind the grille, does that mean those who don't have snorkels will have pressure build up there, and if not, where does the pressure go? I gather you have analyzed the airflow in that area when placing the openings for the snorkels.
With the snorkels, would you say that the car benefits more from increased flow rate or a reduction in turbulence?
The concept is clever, to be sure, and I have no reason to doubt they are worthwhile. I am just curious about the science behind them.
Also, when you refer to the compressor as undersized, are you referring specifically to the 3.3, or the 2.0T as well?
Thanks again and best wishes on this venture. Creating this specialized product for a small market, it's clear you are a genuine enthusiast, so hopefully you will inspire others.
