Awesome thank youView attachment 17446
Wipes them down with 70% running alcohol. 3 light coats of adhesion promoter. 1 tack coat of the black paint... then 3 wet coats. About 3 minutes apart. Let them cure for 5 days.
As promised. Sorry, overcast and sprinkling...Look forward to your full shots tomorrow.
		Nice job, all works well on the HCR & that AWD badge looks sooo much better than the OE that was fitted. Well done, your efforts are well rewarded with the look you have achieved.As promised. Sorry, overcast and sprinkling...
Looks great! Where did you purchase your GT2 badge?
How hard was it to install? And do you know how easy it is to drain and how long u til you have to drain since it is only one can?Added the double baffle catch can today.. thanks k8stingerstore!
It really wasn't to bad once I figured out what went were. They say to check it every 500-1000 miles.. it has a little dip stick built into it so you can check how full it is without unscrewing the whole thing.How hard was it to install? And do you know how easy it is to drain and how long u til you have to drain since it is only one can?
Thanks!
High Performance Exhaust Kit (Custom Y-Neck)How much for product and install
Nice will it just stay open all the time ? Or closed...High Performance Exhaust Kit (Custom Y-Neck)
Paid 3hrs labor@$80, with tax $285
you can use the switch provided. I bought the remote and installed both in the trunk. So in cab I use the remote but if the remote fails, easy hook up to manual switch. Its nascar in your car and then with a push of a button back to stock. They cut in just past the primaries.Nice will it just stay open all the time ? Or closed...
It's not for everyday driving. It's for the track or whenever ya want to f with someone. The beauty is you can turn it off. Down shifts are pure bliss. I manually shift both with paddles and the shifter, I rarely use automatic unless of course I'm doing launch control.Sweet is the sound pretty damn loud then when driving ? Probably too much since it’s right under you
Those do look pretty danged cool; like you can open them up and blast off.It's not for everyday driving. It's for the track or whenever ya want to f with someone. The beauty is you can turn it off. Down shifts are pure bliss.
