I do have an I phone I wouldn’t be surprised it is lol ....POS I phoneI just tried it to and from my yahoo and Gmail accounts and they all worked.
Must be an issue with IOS.
I did just recently get an ios update.... you think that the issue I am pissed ...If you recently updated the IOS, BMS might need to update the app.
EDIT: just updated the app
I just an update on my phone today ... also the I got the firmware 7 on the jb4 today and for some reason my screen does not look like other i don’t have the option to take bit 1 off ??There are no known iOS app issues, we receive logs daily from iOS customers.
I loaded new firmware and still have the previous fual bias values ... do I leave them as isIf you selected FutureUseD, you'll see the BIT options, and unless you did something wrong before never turned it on in the first place. So load v7, make ZERO setting changes, and enjoy. For any addl app questions ask in the app link previously provided.
I hope this new updates loaded correctly on my jb4 ...Yes, no issue.
Some cars will be ok and other will start having problems later on. You can also gap the oem plugs. I gapped mine to .024 and have had no issue and have run all the maps.Does map 1 run safely with stock plugs not gapped? Or is something that shouldn’t be done... I don’t have jb4 but interested in case I want to get it and later change plugs
I had a shop do mine they charged me 160 Canadian. I wanted to keep the oem plugs in there for warranty if something ever happens. If I could go back in time and do it again I’d probably do the denso but oem are working good so far 3000km on them with a lot of wot pulls.Thanks! Wonder what a shop would charge to just regap stock plugs.. I guess if I do that I might as well buy new ones for them to put in ..
100-160.00 should be reasonable.
