The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
It is where the two round adjustable spacers (one on each side of the hatch) strike the body. View attachment 16615
spelling ?? what do you mean ?? take note of the direction ??I say just add the additional washers. I haven't had a problem since. The playdoh seems a bit much.
If you do add the washer just remember to take not of the direct of that part before you remove it.
Yup , this seems to be the final solution , I have 1 set of thin KIa washers and they replaced the trunk latch assembly which eliminated the "rattle" but not the "thunk" going over larger bumps .....................I'll do the extra washers this week . My sunroof frame gets replaced next week ....................Fingers crossed !!!!I did the washer fix over the holidays and the hatch sound has been totally eliminated.
Edit:
To clarify, my car had 2 thin washers on each bolt so the dealer had already tired to fix it. I replaced one of their thin washers with a thicker one and kept one of theirs. So each bolt has a thin dealer washer and a thick stainless steel washer I bought from a hardware store. The true test was this morning with no weight in the back of the car and an outdoor temperature of 14 degrees fahrenheit. Typically at that temperature the hatch would rattle easily over bumps, total silence this morning. What a relief.
I just had this fixed at the dealer. Trunk rattle is gone completely, but I am also noticing a loud pop when releasing the hatch. Do you think this correct? Doesn't sound right to me.I just turned out the two rubber stoppers to spec, an inch, per the TSB and it took care of 98% of the trunk rattle. I then got the replacement part. With the new part the trunk pops loudly when released. Much more pressure on the trunk latch.
Looks like that is all they did for me as well, despite me specifically referencing the TSB. I just took off the pieces to check and found no new washers. That is a little frustrating. I may just go buy some washers and deal with it myself. That additional pressure on the latch doesn't seem right to me. I may try to playdough tip as well. It is great to know what is causing the rattle! It was driving me crazy.They just adjusted those bump stops for mine and the rattle is back, so going to specify Sa322 this time to get them to fix it.
I checked the paperwork and they performed TSBBOD184. I did the playdough test and the strike pads on the left and right are definitely coming into close contact. I tried setting the bump stops to the lowest setting and there was still a loud pop when opening the hatch. Hopefully the additional pressure is OK, just doesn't seem right to me. The rattle is definitely gone, but I cannot visually see what was changed. Good to have a forum to discuss this. Thanks!The loud pop is because the latch has more force on it than it did before, it's a result of their fix since the latch is primarily where the hatch rattle comes from. It's normal but unless they added the thicker washers my bet is the sound will return for you once the bumpers screw themselves back in again, unless they did some other fix that Kia hasn't released a TSB for yet.
"Problem solved", how? What did they do?I had mine in for service and informed them that the rattle was back. After 3 hours of searching they realized that the rattle was coming from my rear spoiler, problem solved.
