KLR STINGER
- Mar 31, 2018
Sweet. I'll get some tomorrow.
Managed to get a log of a launch control WOT - can u please have a quick look to see if all looks ok?Woot!
I like the idea, the simpler the better....Everyone should just buy fuel wires there only like 30 bucks lol....The less simple meaning dont have to put inputs i think the betterQuestion for how we handle fuel settings in v7. With the new logic I don't expect user fuel bias changes will be overly useful and having different suggested settings for different firmware versions is an area of confusion I want to remove. So I'm thinking of hard coding them in the firmware rather than using the fuel bias user adjustment column.
Only drawback here is for those without fuel control wires, by default, logging AFR won't be accurate. Instead we will have a FUD option for disabling fuel control and those without fuel control wire will have to check that option to have accurate AFR logging. There will be no tuning implication so running without fuel wires and the option not selected won't effect performance.
For those who prefer more granular AFR adjustment we will leave that active if selecting another FUD bit to enable it.
Overall I think it's a good move which will make things easier for most of our customers who don't want to bother with fuel settings. Thoughts?
Great! ThanksYes looks normal to me!
Yep I think easier the better when it comes to plug and play devicesQuestion for how we handle fuel settings in v7. With the new logic I don't expect user fuel bias changes will be overly useful and having different suggested settings for different firmware versions is an area of confusion I want to remove. So I'm thinking of hard coding them in the firmware rather than using the fuel bias user adjustment column.
@Terry@BMS Would you be able to provide any kind of info or feedback concerning the Kia Shift Logic bulletin, as far as if you know how it will react with the JB4 running? Trying to decided if I should get it or not during my appointment this coming Friday and haven't been able to find any concrete info on if it's a good or bad thing.
What Kia has an software update ?? Is this for all stinger ... I don’t go to the dealer I do my owm service ..It shouldnt have any effect on the jb4. Just make sure its off when you go in lol.
I was hesitant when they did mine, but i have to say the car drives much better with the update. It used to hard shift alot while it warmed up. Now, its as smooth as butter through all gears even while not up to temp.
Thank you!
I wasn't sure if it would end up being making the car less fun or put more restriction on it, then making the JB4 less fun than it is now.
How long did it take you?
