I’m just wondering how jb4 and Canadian gas play together for you. I have jb4 with fuel wires. The first time I filled up with chevron 94 and was getting pinging even on map 1. I then switched to shell 91 and could get just a hint of ping on map 1 as well. I’m finding the only way I can use jb4 with pump gas is to use a custom map that’s just 1 psi over stock. With E85 mix I have no problem running up to map 5. I’m thinking of trying to run another tank of chevron 94 maybe I just got a bad tank. I have stock plugs gapped to 24 jun mid pipes and catback with k&n filters. Any info from some more Canadians would be great.
