The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
@Terry@BMS, how do you switch tunes or perform updates on the base unit? Or must you but the connect kit?
I was going to hold off on that purchase....at 140.00.
Will the base unit purchase also allow me to run data logs?
You don't. You install the base tune and enjoy it, or drop $35 on a data cable to connect to your laptop for logs and map changes using the free windows and MAC software. For the phone stuff it's $170 total for adapter and app.
Looking forward to some new dragy times with the new tires!Finally upgraded the tires. Enkei RPF1 18x9.5" rims, some half used 285/40/18 Nitto 555Rs we had on our M4. The stock 19s and tires were 58# each, these 46#. Look decent, may do the front to match, if traction is improved with these.
So, basically if I’m adding the fuel wires and need to see the logs to monitor detonation... I’ll need the data cable or Bluetooth? I looked and saw “starting” at 35.00 and didn’t realize it was actually 170.00 for it.
We can’t use TorquePro to log because it won’t be accurate with the piggy back correct?
@Terry@BMS ... if We don’t connect the OBD2.... what options are lost?
Rear tire vs front tire height difference won't cause any issues?
Certainly won’t being that it’s RWD. Other than the unleveled look shouldn’t be an issue. An AWD system must be kept close to the same diameters, RWD could care less, that’s why a lot of RWD cars run true staggered set-ups like a 20” rear/19”front.
Don't see why it would, it's RWD.
When are we getting some numbers? Turkey can wait! Let's see what DRs are capable of.
Terry we have everything that you make for the stinger running map 3, 93oct, fuel wires, plugs and our own intake with out a problem. We’re getting it on the Dyno tomorrow to look at some things and then putting tires on her and racing Sunday. Will post all that for you guys when it happens.
Im going to buy your pedal tuner, but is there any info out there about gains with it installed? I like the product. Wheve used them on evo X and Mazdas in the past.
Map 1 JB4 only +29whp/78wtq:I’m going to order the data cable for the short term and I guess the fuel wires. Is there any benefit to running the base map with fuel wires? I see dynos of map1 with wires.
And do the fuel wires add additional safety?
Map1 stock and map1 intakes. Not much difference.
