The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
I used ramps on the front, then I jacked up one side of rear on stand. That was enough space to get in there. But ymmv if you are a big dude you may have trouble getting enough space to break bolts loose. Also since u just have 2 stands this will be a pain you would need to jack up front then rear, then front then rear again for removal and install. Either get 2 more stands, or a pair of ramps to help would be my suggestionWhat method are people using without a lift? Can ramps get you high enough with a crawler? Got all the time in the world... But one floor jack and two stands. Thinking about ramps if they help....
I've never been able to use a crawler under a car on just ramps and I'm not a big guyWhat method are people using without a lift? Can ramps get you high enough with a crawler? Got all the time in the world... But one floor jack and two stands. Thinking about ramps if they help....
Yeh given how low our stingers are its tight. My front end was on ramps I barely fit with a creeper. The rear I jacked up one side only but was on the ground w no creeper.I've never been able to use a crawler under a car on just ramps and I'm not a big guy
I assume these fit perfect on a 2019?
I have a jack and 4 jack stands so that's what I use. Just get it as high up as I can with the stands and that's enough with an impact gun. If you don't have a impact gun that is still gonna be a bit of a struggleWhat method are people using without a lift? Can ramps get you high enough with a crawler? Got all the time in the world... But one floor jack and two stands. Thinking about ramps if they help....
Do itUghhhhh. I wanted to leave this damn thing alone... Thanks a lot.
Do it
So I really want to pick these up, but just to confirm 100%, 1) there's no drone and 2) there's a somewhat notable increase in performance? Where is that gain? I feel that AWD jumps off the line aggressively, but lacks in mid- to high-end pickup (i.e., passing power on the freeway). Looking forward to input before purchasing. Thanks!
Nice garage floor
The jun downpipes don’t hang down Like that at the bend. They do hang down 1/2 inch more then stock though."@CeramicGT2 wrote: My ONLY critique, and it may be a non issue (time will tell) is the back end of the down pipes hang a bit lower than stock. But I never plan to lower my car, so I’m not worried"
Oh man, I am worried. My car has installed the Eibach's springs and is lower, so I should not install these downpipes in my car...d@mn
